Electrical problem!!!!!
Old Jul 7, 2010 | 04:05 PM
delgal's Avatar
delgal
Default Electrical problem!!!!!
hello,
my corvette a 1976 electrical problem
my power windows stopped working, the commands: speedometer, tachometer, ammeter (voltmeter), fuel gauge, oil pressure gauge, temperature gauge ...
nothing works !!!!!!!!
I replace all the fuse!! but nothing works ....
corvette runs smoothly, the headlight, the front and rear no problem!!
can you help me?
delgal
Old Jul 7, 2010 | 04:17 PM
mrvette's Avatar
mrvette
Look really clearly at your fuse block under the dash there, those things have a nasty habit of rusting, and affecting the wiring to the spring loaded fuse holders....then there is the ignition switch itself....
you can pull the inside fuse block off with just 3 bolts, one to the bulkhead connector...either 5/16 or 3/8 nut driver....and then the 2 5/16 bolt heads on the inside.... that should enable enough room to investigate any burnt/bad/rust wiring
Old Jul 7, 2010 | 04:26 PM
...Roger...'s Avatar
...Roger...
Check the fusible link at the bulkhead connector (engine side).
Old Jul 7, 2010 | 04:39 PM
delgal's Avatar
delgal
pfffffffffffffff ok ok
about power windows,
I found this, is that the small module on the drawing (29 300) could be the cause?
how to test it?
[IMG][/IMG]
Old Jul 7, 2010 | 04:40 PM
delgal's Avatar
delgal
Old Jul 7, 2010 | 04:52 PM
...Roger...
Thats the window relay. Check the 12 pink for 12 volts.
You have a lot of things not working.
Tell use more of whats working , headlights work ,taillights ? parking lights ? radio ? turn signals ? Horn ? etc.
Old Jul 7, 2010 | 04:55 PM
...Roger...
Not referring to the little glass fuses. I'm talking about a wire that is designed to burn in 2 to protect a circuit like a glass fuse. Your 76 has around 6 fusible links. Here is a thread where some fusible link chatter went on. Great reading.
http://forums.corvetteforum.com/c3-t...ad-merged.html
Old Jul 7, 2010 | 05:00 PM
delgal's Avatar
delgal
Would you have an image that can see?
Old Jul 7, 2010 | 05:33 PM
...Roger...
I don't have one of the ones I'm referring to on your 76 at the bulkhead connector.
I can show you some other fusible links on other years of cars if you would like to see them.
Old Jul 7, 2010 | 05:50 PM
delgal's Avatar
delgal
yes, thank you
Old Jul 7, 2010 | 05:51 PM
...Roger...
The links in this pic are the orange and the larger black wire on the left in the pic. The large cylinder black plastic thingys are just connectors. The actual links are the wire.
This shows an orange fusible link, its the loop.
This is a link at the starter. Its the brown wire between the round black plastic connectors. This is from Duke94s car.
To Electrical problem!!!!!
