1968 Passengers side mirror
Old Jul 8, 2010 | 04:31 AM
robs68's Avatar
robs68
Default 1968 Passengers side mirror
Well after further research I guess the question I need to ask is, has anyone installed right side mirror using the well nut kit they all come with. If so were you happy with install and does it feel solid.Any issues over time with this install. Thanks.
P.S. I don't see any way to install a plate on the inside without cutting holes in 2 layers of steel inner panels.
Old Jul 8, 2010 | 09:41 AM
CFD E59's Avatar
CFD E59
I can tell you, it is very easy and the mirror will stay on without any movement. I installed a passenger side mirror over ten years ago and is as solid as the day I installed it. Measure twice before drilling holes. You'll be happy you did.
Old Jul 8, 2010 | 09:43 AM
oldsarge's Avatar
oldsarge
Did the same, no problems.
CFD E59's Avatar
CFD E59
I also wasn't sure the nut kit would hold, but it does very well.
To 1968 Passengers side mirror
