81 idle help
Old Mar 23, 2002 | 03:28 PM
Trent81's Avatar
Trent81
Default 81 idle help
My Vette (81) will not idle down after warm up. It idle's at around 1500 rpm's and will not idle down to the 800 rpm range it is supposed to be in. Car runs really good with no codes from the ECM. My shop manuel does not address this problem. Anyone have any suggestions?
Trent81
Old Mar 23, 2002 | 03:35 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: 81 idle help (Trent81)
fast idle cam is stuck in the up position,or the choke is not open all the way. :chevy
Old Mar 23, 2002 | 03:40 PM
Trent81's Avatar
Trent81
Default Re: 81 idle help (clem zahrobsky)
Clem,
Thanks, Now how do I fix it? Any help will be greatly appreciated.
Trent :confused:
Old Mar 23, 2002 | 03:53 PM
clem zahrobsky
Cruise-In I Veteran
your best bet is to pick up doug roes Q jet book and it gives all you need to know about setting the carb. post the number that is on the drivers side of the carb starting with170----- and i will post the specs. :chevy
To 81 idle help
