Badly bent pushrods
Old Jul 11, 2010 | 07:46 PM
Timsride's Avatar
Timsride
I think Larrywalk is right You should check timing chain and make sure its not out by one or more tooth positions. Bent intakes are the result of too much advance, most of the time.
Old Jul 11, 2010 | 08:08 PM
forvicjr's Avatar
forvicjr
To all that responded, Im sorry that i took you alls time over such a stupid mistake on my part. I pulled the timing cover to discover that the cam was infact advanced. Ive built 30 plus engines in my time and im only 32 years old.The timing set i used was kinda misleading with the timing marks. Not to lay it all on the timing set, I guess I shoulda looked closer.This is the first time this has happened to me after all the engines built previously.This forum however is a great tool to have and I thank all whom took time to question some of the steps i took on this thing to try to figure out just what the hell was going on. As i said this is only the second BB for me and as my luck would have it, what hung me was the same procedure for BB and SB alike. O well guess ill fix it and consider it a lesson to pay more attention in the future.Again thanks to all.
Old Jul 11, 2010 | 08:11 PM
Timsride's Avatar
Timsride
At least You were able to find the problem. I also forgot to mention on earlier post, Nice BB.
Old Jul 11, 2010 | 08:49 PM
forvicjr's Avatar
forvicjr
Thanks for the compliment,Although it would be even prettier, in the car and running without timing issues
Old Jul 11, 2010 | 10:20 PM
spinadog's Avatar
spinadog
I feel your pain with a multi-keyway timing chain setup. Me and a buddy must have argued for a day and drank a case of beer about what was right and should dots be together or both upright. But, fussing, testing and some reality checking - we got it right.
Good luck on your rebuild - at least you know that you will never do this mistake again.
Old Jul 11, 2010 | 11:33 PM
UBETRUN's Avatar
UBETRUN
Am I reading this thread correctly that you bent pushrods and intake valves *by hand*? That the motor was never started, all this damage was done turning it over manually??
Old Jul 11, 2010 | 11:34 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Well..that makes sense now then. I just couldn't see how that cam could get things near those pistons without being way advanced.
Good news is you didn't hurt anything real dramatic. Yes,,,you whacked some intake valves and bent some pushrods. Likely the guides are all still fine and in fact the valve job really shouldn't be hurt any.
Get some new valves and pushrods and stick it back together. You'll be running in no time!
This might be a good time to actually degree the cam in. You've got it all apart and no better time to learn than right now!
Is this the timing set with a suare, a circle and a diamond for marks? If so...you can look closely at the keyways. If using the keyway with the rounded top you use the circle, if using the keyway with the pointed top...you use the diamond....and the square goes for the square cut keyway. They all have something similar to that. But even with all that, there can be tolerance stack up with crank/cam keyways/dowels and with gear sets. Some cams are ground already advanced 4*..so you don't need to add more.
Good luck!
JIM
Old Jul 12, 2010 | 07:38 AM
forvicjr's Avatar
forvicjr
427, I was so pissed at that damn timing chain I pulled it off and chunked it in the trash. Purchased another with much clearer markings,As far as degreeing i must have read your mind. I had a 20'' wheel made a couple of years ago, Its now set up and ready to be degreed in once i get off today. I hope to to that and on my way home pick some valves up and lapping compound. Maybe by eleven or so tonight it will at least be sitting in the car, ready to start tomorrow.
Old Jul 12, 2010 | 07:44 AM
forvicjr's Avatar
forvicjr
Didnt discover while turning by hand. hyd lifters and tightness of new engine masked problem. Primed engine rolled it over with the starter and well, you see the pics
Old Jul 12, 2010 | 11:43 AM
ctk30's Avatar
ctk30
This is probably what my engine would have looked like if I didn't degree my cam in
Old Jul 12, 2010 | 12:32 PM
jackson's Avatar
jackson
static compression probably about 8.3 - 8.5:1 ... street-use won't like too much cam.
Old Jul 12, 2010 | 04:11 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I had exactly the same issue when I built my engine, the edelbrock timing sprocket was not clear and they stamped the marks on the wrong position, thankfully I degreed my cam at that time and discovered the problem before anything goes wrong. Now I degree EVERY camshaft I install no matter how small/mild it is.
Old Jul 13, 2010 | 08:41 PM
  #33
forvicjr's Avatar
forvicjr
UPDATE, degreed cam, hundred thirty thosandths valve to piston clearance.Didnt even measure exhaust, its wide open. Cams straight up didnt have to move it any , got 4 degrees built in. Got her running, and man it sounds good. cant move it though, no calipers or brake rotors. This will be next! Any one got slotted rear rotors for sale? or O ringed calipers sitting collecting dust in there shop? Thanks all, corvette forum is the da shet!!
Will post video as soon as i figure out how, who wants to hear a rat run with no muffs???
Old Jul 14, 2010 | 01:11 AM
  #34
gkull's Avatar
gkull
You are not the first. I was involved in a hot rod small block build. when we were adjusting the roller rocker lashes after a few we could not turn the motor over.
small blocks have bigger valve cuts for the intakes. The center cylinders have two exhausts valves together. The local speed shop that balanced the motor mounted the pistons with the spriral locks like a big block piston arrangement. We just gapped the rings and installed them 1-8 without seeing the error. Some buddy said maybe it's just tight and why not bump the starter to set the next rocker.
It bent the intake valves on band new AFR heads.
Very sorry about your like experience
Old Jul 14, 2010 | 07:43 AM
  #35
70BBvert's Avatar
70BBvert
Glad you got it figured out & running. And yes, have a pair of calipers gathering dust. They are stamped by VBP so Ii believe they are stainless steel sleeved, not sure if they are O - ring or the regular seal
Jim
Old Jul 14, 2010 | 11:01 AM
  #36
Les's Avatar
Les
I'm glad you got it sorted out and running so quickly. As for the vid- hell yea! I'm always in for hearing an unmuffled rat.
Old Jul 14, 2010 | 02:41 PM
  #37
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
The engine never fired,never. I did rol the motor by hand several times BUT the lifters werent pumped up tight with oil ,so when i turned it the valves hit but was just colapsing the lifter. The motor being tight camaflaged the interferance with the valves. This is why i didnt catch this sooner. Wish i did, so far im seeing about 600.00 in costs to get it back in the car. All this happened when i was getting ready to drop the distributor. Bumping engine over with starter to find #1.
You kept saying you were rolling it over buy hand and then post 29 you finally say you used the starter
Anyway when building a motor you always degree the cam, 99% of the time it is right on the money and sometimes you figure you just wasted an hour degreeing it but it will catch problems like you had.
I hope you have many miles of enjoyable cruising
To Badly bent pushrods
Old Jul 14, 2010 | 03:07 PM
  #38
gerry72's Avatar
gerry72
Originally Posted by spinadog
...what was right and should dots be together or both upright...
It would have been inconsequential either way. Lining them up with the cam dot down and the crank dot up gives you the same thing as crank up and cam up, cam down and crank down, or cam up and crank down. The dots will find these orientations in two crankshaft revolutions anyway. It's just easier to align them when they are closer together with the crank up and cam down. And this orientation is the only one that gives you TDC on the ignition, which could save you some time depending on what you're doing.
Old Jul 14, 2010 | 06:47 PM
  #39
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Originally Posted by gerry72
...Lining them up with the cam dot down and the crank dot up gives you the same thing as crank up and cam up, cam down and crank down, or cam up and crank down. The dots will find these orientations in two crankshaft revolutions anyway....
Whoa!...
Crank up and cam down (or up) works, but crank down will never work!
Old Jul 15, 2010 | 01:32 AM
  #40
427Hotrod's Avatar
427Hotrod
When the dots are lined up together...thats TDC compression on #6....#1 is in overlap.
JIM
