vintage air install
Old Jul 10, 2010 | 03:24 PM
Hells Bells 73's Avatar
Hells Bells 73
Default vintage air install
i have 73 with ac,want to install a vintage air sys. i am very good with anything that needs to be fixed.i will not be able to charge it ,or can I? how much do they charge to do the complete job ?Ron.
Old Jul 10, 2010 | 05:42 PM
nomocrap's Avatar
nomocrap
I have a 1979 and planning the same, I am going to use the kit from Nostalgic air. I live near you in south Dennis. My email is "nomocrap@comcast.net" JAY
Old Jul 11, 2010 | 12:14 AM
TimAT's Avatar
TimAT
You need to pull a vacuum on any a/c system that's been open before you charge it. Charging is no trick- you can get R-134 and the correct oil at your local parts house. (probably won't need oil, the Classic Air system I installed had the correct amount of oil in it). If you can get a good vacuum on the system and it holds, you can add the spec'd amount of 134 and be done.
To vintage air install
