Engine rebuild '72 LT-1
Yes a cam and heads will really wake up the LT1. I hope headers and good exhaust are part of it, they need to breathe. The stock manifolds and exhaust don't flow enough.
'nuff said.
With a 350, I'd tend towards a 180cc or max 195cc head. If you really want a stock look, consider going with a set of Dart/World Products iron heads and spending a little porting money on them. Matched with a roller cam, that'll get you in the ballpark. Note that roller rockers aren't going to fit under the stock valve covers, so you'll be looking at getting a set of aftermarket knock-offs, cutting the drippers and putting on a spacer.
The LT-1 intake is a pretty decent high-rise dual-plane; I still have one of them on the shelf myself. But it is a significant limiting factor on the heads, especially something like an AFR.
I fit roller rockers under LT-1 aluminum valve covers all the time, I have to crush the oil baffles to clear rocker bodies (just a slight amount of crush.) The rollers will fit if you measure rocker heigths and cut down the polylock nuts about 0.200-0.250" and also make sure the set screws are the proper length after shortening the nuts. The covers will clear on most cams under 0.600" lift. You will have to find a set of 1969 covers without the drippers or cut them off to clear the roller rockers (can be done with a Dremel tool and cut-off wheel at home.)
When I put a set of Hooker Super Comp headers on the same motor with 4.56 gears, the same GM intake went 12.28@117MPH but, no longer looked like a sleeper (HP gain from headers alone, around 25HP, torque gain WAY MORE through the entire range, about 35ft/lbs at it's peak just from headers.) That carb on both motors was a re-worked "swap meet special" Holley #4777 650DP with a milled off choke horn and casting polishing by Dremel tool, many would say it was too small but, in track testing against a 750DP the 60ft time went off while the MPH went up 1.5MPH but, because the Vette is mainly an autocross car, I went with the throttle response of the 650DP.
Yes it takes some work but when someone freeks out at the fast Vette at the drags and you say, "I think it's pretty stock inside, it's just one of the better running ones they made" that right there is PRICELESS!
Do the sensible thing: save the LT-1 engine and, thereby, maintain the intrinsic value of your car. You can buy a crate engine or build one with another block [with 4-bolt mains] for a little more money and not risk the integrity of your 'original' engine. Then you can have a ball with the new power and sleep better at night that you didn't do something "dumb".
http://www.dartheads.com/products/ai...itfile_id/113/
My thoughts on the covers was based on the thought that he wouldn't want to cut up a set of factory original covers.
While they cost more than a new set of RHS or Dart heads (if you can't do the work yourself), they look right on a "stock" LT-1. The heads will have stock valve covers hiding all the good hardware below: Comp Cams Pro Magnum roller rockers, 7/16 studes, Beehive springs, tool steel retainers, ect.
Intake runner size is around 175cc of volume with full porting job, they could be made bigger but the Chevy hi-rise intake flange is pretty thin above the intake runners and going to a #1205 Fel Pro intake gasket size won't really help the flow, it will just kill port velocity (whats he talking about?
) and increase the chances of getting a gasket leak.I think any cylinder head runner over about 180cc on the intake side is getting too big for a street driven 350cu/in Chevy but, what do I know about building motors
), Mahle 383 forged pistons (again another "sale item" and they have right compression heigth for my 5.85 rod 355 motor), Melling "M select" oil pump (std volume high pressure spring installed, pump housing deburred and ported because I like to do that kind of thing in my spare time
), Cloyes true roller chain, Billet timing gears, Ultradyne flat tappet cam, AC Delco "585" edge orifice lifters in grooved lifter bores (my stock on these is getting low!) New harmonic balancer, and a lot of EFFING grinding/detailing of engine block/oil passages by yours trully (let's just say, I'm not a "crate motor" type of guy.) Anyone want to run their sub $3500"crate motor" against my sub $3500 355 Chebbie? I'll even let you bring out your 383 motors
Original block with flat tops
Dart Pro 1 heads
Edelbrock Rollin Thunder roller cam kit
Summit roller rockers
I figure I should get about 10:1 and a power range of 1500-6500
I know it's not cheap, but I don't plan on doing this again.
Am I nuts?
Lets call it $50 per one measly hp. The same $1000 can buy you a great set of headers and dual free flowing exhaust or .............
With the oil we have now, a roller cam is insurance as well. I also got different opinions on horsepower increase, much higher.
Do buy cams from Comp, Bullet (my favorite brand), Lunati, Isky, Crower, Crane or one that your local automotive machinist reccomends (that same machinist can look up the specs on a Edelbrock cam, order it from Melling and sell it to you at about 1/2 the cost you'll pay to Vic for his fancy packaging if you really want 10-20 year old lobe designs in your motor.)
PM me if you need help picking out a cam for your LT-1. Sounds simular to what I built for my wife's 70 Vette.
