Checked the vacuum today and...
Old Mar 24, 2002 | 12:32 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Checked the vacuum today and...
I'm running 20lbs after the installation of the 1.6 rockers. Thats up from 16. It's that to much vacuum or do I need to adust the timing? Even reving it, it jumps back up to 20.
Old Mar 24, 2002 | 12:43 AM
Carl in LA's Avatar
Carl in LA
Default Re: Checked the vacuum today and... (Budman78)
I like hearing that you got 20 inches after the rocker arm change... That sounds quite normal. I wonder what the corolation is with the steeper angle rockers... longer valve opening? Deeper opening valve???
Are you in California?
Old Mar 24, 2002 | 12:49 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
Default Re: Checked the vacuum today and... (Carl in LA)
Nope, Tejas. But I bought my car in Palm Desert.
Old Mar 24, 2002 | 01:02 AM
Carl in LA's Avatar
Carl in LA
And thats how a 1978 california car ends up with FI. Dealing with the smog ***** have me learning to luv' my carb.
Do you think the legislators will ever learn that FI make fewer pollutants than carbs do???
Old Mar 24, 2002 | 01:22 AM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
The higher vacuum shouldn't be a problem unless it due to an over lean mixture, which I doubt would result from the rocker arm change. If anything, I'd expect a slightly lower vacuum reading from the 1.6's. Assuming no other changes were made, I suspect that the increase came as a result of the valve adjustment.
To Checked the vacuum today and...
