need headlight actuator valve bushing
Old Jul 14, 2010 | 08:26 AM
not2brite's Avatar
not2brite
Cruising
Default need headlight actuator valve bushing
Hi...newbie here. I'm tearing into a 1973 corvette driver. One headlight actuator valve doesn't hold vacumn. The other is fine. I used info from the web (thanks someone!!) to open the valve up and found that the rubber "bushing" that is pinned to the rod end is damaged...ripped. Can I get just that small rubber bushing or do I have to buy the whole unit?
Old Jul 14, 2010 | 08:48 AM
...Roger...'s Avatar
...Roger...
I doubt you can find that part other than finding a used one.
I'm in the process of having an aluminum piston made that will have 2 o-rings in place of the 1 piece rubber piston.
Old Jul 16, 2010 | 12:43 PM
not2brite's Avatar
not2brite
Cruising
Thanks. I figured as much. For the want of a nail.....
Old Jul 16, 2010 | 04:57 PM
GeorgeS's Avatar
GeorgeS
Do a search on Willcox Chorvette. He has actuators and I believe he also has rebuild kits. I just ordered a pair of new ones from him for $120. Individual units are $55 each. Beats messing with it then buying a new one afterwards. ( I got two so they match)
Old Jul 16, 2010 | 05:14 PM
BHRIG's Avatar
BHRIG
Would it have been less money if you bought 2@$55.00 or a pair at $120.00?
Old Jul 16, 2010 | 05:44 PM
CCrane65's Avatar
CCrane65
I think he's talking about the relay rather than the actuator. The relay has a dumbbell shaped piston inside that slides up and down to change to flow of the vacuum between the front hose and the rear hose of the actuator.
cc
Old Jul 16, 2010 | 09:49 PM
...Roger...
cc
Cliff , I'm having an aluminum prototype dumbbell made that will take 2 o-rings. Hopefully I get to test it soon.
Old Jul 16, 2010 | 10:06 PM
stevelischynsky's Avatar
stevelischynsky
Roger,
When you get it working, can you post the details
Steve L
73 coupe since new
Old Jul 16, 2010 | 10:14 PM
CCrane65's Avatar
CCrane65
I read on another post that you can remove the dumbbell from the bottom if you are careful. Did you do that?
I tried the clamp ring removal method last winter and that was too difficult to do without messing up the plastic and the ring.
cc
Old Jul 16, 2010 | 10:27 PM
...Roger...
cc
Someone else was doing it by crushing the washer but thats pretty hard to do with the limited space. I made a little tool to put in your drill that removes the crush points on the rod and the piston slips right out. I'm hoping these aluminum pistons will be a long term fix, if the o-rings go bad just put new ones on. The aluminum might be changed to plastic once we get the sizing right.
Old Jul 16, 2010 | 11:48 PM
Dave J's Avatar
Dave J
I also have been working on a replacement piston for relays. I've been working with a plastics engineer and we are settling on delrin as a material, and will be testing 3 different o-rings. Replacement will be through the bottom of relay, with a tube fitting over the existing shaft. The new piston will be drilled to accept the tube inside. Results so far look real good. Will know much more toward the end of next week.
Old Jul 17, 2010 | 06:37 AM
7T1vette's Avatar
7T1vette
The the OP:
If you can determine what type of material that 'bushing' is made of, just see what hardware stores (or your junk drawer) has that might fill the bill. A bushing is a pretty simple part: the right material (or decent substitute); correct length, ID & OD are all you need. Most hardware stores carry rubber and nylon "spacers". If you can modify one, give it a try. What have you lost? [nothing but a little time and pocket change]
You can always buy a new one if that doesn't work or hold up.
Old Jul 17, 2010 | 08:05 AM
...Roger...
Originally Posted by 7T1vette
The the OP:
I think when he says "bushing" he's talking about the rubber piston , I'll get a pic and post it.
OP you can clean the rubber piston and smear on silicone to fill the tear. Some are fitting o rings inside the ends to help with the seal.
There are several threads showing diff ways to fix or rebuild the relays.
Old Jul 17, 2010 | 08:13 AM
...Roger...
Delrin is what were talking about also. Aluminum will have to be anodized.
Sounds like were thinking somewhat alike. Whats the tube ? How are you removing the crimped end ? What are you going to use in place of the crimped end ?
The most important question, have you considered the added resistance of the o-rings might make the dreaded " wiper door pops up and goes back down on start up" worse ?
Old Jul 17, 2010 | 11:00 AM
doctorgene's Avatar
doctorgene
Yes Sir; What do you want for your old Headlight Door Control Actuators, If you buy new ones. The seal kit repair set is 24.95 in one of the vendor books. Have a nice day. Gene
Old Jul 17, 2010 | 11:20 AM
GeorgeS's Avatar
GeorgeS
cc
No I wasn't. The Actuator is the can inside the headlight assemble. It has the bumbell shaped plunger that opens and closed the door when vaccume is applied. The relay sits in the center front of the grill area and is used to revurse the vaccume flow.
The $55 was for one actuator (list). The $120 was for two and included tax, title, tip and destination charges.
Old Jul 17, 2010 | 11:57 PM
CCrane65's Avatar
CCrane65
An actuator has a threaded rod sticking out of the front with an accordion seal and has a clevis screwed onto it which in turn has a rod through the eye of the clevis with springs connected to it on either side of the headlight elbow. Inside the actuator is a diaphragm which has the other end of the threaded rod attached to it.
I'm not understanding which piece you are saying is a dumbbell shaped plunger.
cc
To need headlight actuator valve bushing
Old Jul 20, 2010 | 09:42 AM
not2brite's Avatar
not2brite
Cruising
Great site!!! To clarify just for fun...I'm looking at the headlight actuator RELAY valve, not the larger headlight actuator valve. It moves vacumn between the green hose and the red hose for each headlight. (there is one for each light). Yellow hose connects to the middle, and a small hose to the top of the diaphram housing. A small rubber bushing slides up and down within the tube on a rod to allow one or the other hose to get vacumn....which then goes to the bigger headlight actuator. The bushing, in it's virgin state, is a tubelike piece of rubber legthwise on the rod with sealing flaps on each end. Those thin sealing flaps are delicate, and mine have ripped. The devil in this detail is that it has to run strictly on vacumn, so there can't be much resistence to the bushing's movement within the tube. anyway, thanks for all the thoughts. I'll keep checking around. If we knew who made the ones for sale in all the catalogs, maybe I could find out a source for the part.
Old Jul 20, 2010 | 10:22 AM
Mike Ward's Avatar
Mike Ward
I think using the word 'actuator' confused everyone, including me. These are call simply 'relays in the hobby. I'm familiar with the innards of the relay but not with the damaged piece you're referring to. Got a picture?
Old Jul 20, 2010 | 10:53 AM
wcsinx's Avatar
wcsinx
Any updates?
I would be very interested in a product that replaces the dumbell seal.
