Right Rear Clunking
Old Jul 17, 2010 | 09:06 PM
fgp73's Avatar
fgp73
Default Right Rear Clunking
Recently my car ('73 L-48 4 speed) started a weird and loud clunking in the right rear of the car during acceleration..the odd part is that it only seems to happen after the car is driven for a while and it gets hot. Last year I had a new differential put in and the right rear bearing replaced. The clunking seems to happen mostly while turning after being stopped (turning after a red light or stop sign). Today it happened after I went for a 30 minute drive while pulling in my driveway (which is an uphill driveway)...I stopped on the grade and then accelerated while turning left in order to turn the car around and it made the loud clunk during both times that I repeated the exercise...does this sound like a bad u-joint...any thoughts? The car almost feels like I run over a rock when it makes the noise.
Old Jul 18, 2010 | 03:57 PM
colin75's Avatar
colin75
almost positive its your clutches in your posi. i bet if you change your fluid and add gm additive itll quit. use the search option on your issue
Old Jul 18, 2010 | 05:09 PM
vetluvr's Avatar
vetluvr
St. Jude Donor '08
Trailing arm shims missing?
Old Jul 18, 2010 | 05:18 PM
roy69's Avatar
roy69
Originally Posted by fgp73
................ The car almost feels like I run over a rock when it makes the noise.
Thats exactly the feeling I had a few weeks back ...... changed the rear end fluid and havent had the problem since.
Old Jul 20, 2010 | 03:28 PM
77moneypit's Avatar
77moneypit
3rd Gear
I had a similar problem a few years back. It ended up being the half shaft retainer in the rear diff that had sheared off. Jack it up and see if you can pull the tire out towards you, or push it in...if there is a lot of play that could be your problem.
Old Jul 20, 2010 | 10:07 PM
76yellow's Avatar
76yellow
I have the same issue with my 73. What is the correct fluid & additive to use ?
Old Jul 20, 2010 | 10:16 PM
roy69's Avatar
roy69
A number of posts say that the modern synthetics work grea, but I chose to use the GM Lube and Posi Additive. Corvette Central carries those, and I'm sure other vendors do as well. My manuals said I would need two of the 23 oz bottles of rear end lube, plus the additive. That left me a few ounces short - order 3 bottles.
Old Jul 21, 2010 | 08:19 AM
Phil Zell's Avatar
Phil Zell
Buy them from your local Chevy dealer, as far as I know they are still available
Old Jul 21, 2010 | 10:06 PM
psycho dad's Avatar
psycho dad
Yep dealer has the additive, I used valvoline 90w from the parts store.
Put the additive in first, or you may overfill with lube and not leave enough room. Go to a parking lot and do some figure 8's to work in tha additive.
To Right Rear Clunking
