Well it's about that time in my project. Ordered a motive power bleeder so while i'm waiting on that i figured i'd tackle the disaster that the previous owner made.
They took out the headlights, sealed them up, and painted over it all(really poorly).
You can see where it was cracking on it's own before i even started tearing into things.
I chipped away at the old paint to find that everything had this brown undercoating. Primer? Bondo?
Some of the cracks were already big enough to get a hack saw through. From underneath I can see a slight outline of where the headlights should be going....i hope.
I hope that doesn't happen to mine! I just sealed mine up with resin and fiberglass cloth. I'm going with my headlamps behind the grill with my new paint job. You're assembly does look nice
depending on how long ago they were sealed over could be nitrostan that was once red and faded or a mixture of nitrostans they had lying around it came in red green and blue since the brown is thin. also could be a old lacquer primer i do belive there was a cheapo company at one time that made a brown primer.
By the looks of the way thats cracking its all bondo in the holes you could probably get away with tapping that from underneath with a body hammer and it breaking itself away from the car.
and on the racing bit sealing them up gave better air flow to the rad. by the looks and location or the headlight holes you would think it would be better to leave them open as they would be like 2 big snorkles straight to the rad.
Yeah i really hope I can eventually just tap it with a hammer and get them to pop out. I can weaken them some where they're already cracking but the upper and lower parts aren't cracking as bad so it's hard to get it started.
I used a knife to dig into it a bit thinking they used the old lens and sealed around that but it was all soft so it must be bondo.
The only thing i see from the pic that might be bothersome is shown by the green arrow in your pick now that looks like a screw in this pic maybe just some bodyfiller or undercoating can't really tell but if thats a screw calls for alarm as they may have the original covers or possibly something else mounted below that mudding job. But in either case a few light taps working around the edge should make that old filler thats water logged hence the crack pop out. good luck.
Can you tell me where did you get this HID light assemblies? they look great!
Hamad I bought mine on ebay, but would suggest theretrofit.com due to their good prices and fast shipping. I would also suggest their sealed projectors since you won't have to fabricate sealing them like I had to http://www.theretrofitsource.com/pro...roducts_id=141
Punisher if you need the covers, I have all the parts I removed, send me an email
Well I just tackled the openings and it didn't go as smoothly as i had hoped but i got it done in a way.
I hit the first one with a big hammer and it broke free for about 90% of it. The 10% left that was stuck really well might have taken some of the body's fiberglass so i'll have to learn how to repair that.
On the other side i used a heat gun to melt the black tar underneath to expose the fiberglass lip. I then used a jigsaw from up above to follow that lip as best i could. Most places i'll need to sand the rest of the bondo away and I went a tad deep in others but it worked out a bit smoother on that side.
area where i was a bit too far from the lip so a little sanding will get me close.
Area where the paint crack didn't match up to the fiberglass lip meaning it's a bit weakened in that area.
Overall it's hard to tell where exactly i need to be cutting without ever seeing it original but i followed that small lip thinking it was stock and hoped that was what i needed.
Not sure how i'm going to fix the broken fiberglass areas that are still cracked and weren't in need of cutting out.
Also not sure how the headlight assemblies go into the car. Seems like i have to take the hood off, then a center support beam for the bumper to make room for them.
Hi pv,
The head light assemblies can go in through the grill openings.
I would take the actuators, head-lights, and the long flat arm on the outer side of the mechanism off before putting the doors in place. After adjusting the door gaps you can put the rest of the parts in place pretty easily from the front, rear and below.
Good Luck with your fiberglass work.
Regards,
Alan
The last picture shows the allen wrench screw in the stop on each of the pivots that are used to locate the doors side to side.
looking good as for the lil areas that need some attention that you cut to far or removed some fiberglass that hole you might want to use mat and resin or just use duraglas and touch that up then body filler over that. while your at it there you have the chance to make your gaps whatever you want them to be. just don't go 2 tight
