Q jet rebuild or replace
Old Jul 18, 2010 | 10:49 PM
mfpvette80's Avatar
mfpvette80
Default Q jet rebuild or replace
My 1980 with a 290 HP crate engine, RV cam, and true dual exhaust is beginning to have idling problems, and has experienced a few bad backfires out the carb. The Q jet is original and hasn't been rebuilt. Is it worth the effort to rebuild it or is a Holly street avenger a better choice? I don't race the car, but enjoy decent performance. Any comments on the process of rebuilding a Q jet? Is a better carb option available at a decent price?
Old Jul 18, 2010 | 11:30 PM
marz's Avatar
marz
You can get very good performance from a Qjet if it is rebuilt correctly. You might take a look at Car Craft magazine and do a search for rebuilding a Qjet carb. They had an excellent rebuild article on it this summer. Can't remember what issue it was though. May be less expensive to buy yourself a Holley too. Compare prices on both.
Old Jul 19, 2010 | 12:16 AM
volition's Avatar
volition
There really is no "better" than a Quadrajet. They will all produce similar numbers when tuned properly but only your Quadrajet will work properly with your car (read: idle control for ac, emissions provisions, choke mechanism, etc)
Top quality rebuilds can run you into the $200-$400 range depending on where you send it to. I would suggest Cliff's ( Cliff R on the forum ) as he can get all of the performance you need while keeping full factory functionality of a Quadrajet.
Restoring Quadrajets to running condition is always worth the money as it really doesn't cost any more than a new aftermarket carb and offers superior functionality for street driven cars who need to pass emissions and retain factory ac.
Old Jul 19, 2010 | 12:58 AM
snoopykissedlucy's Avatar
snoopykissedlucy
I'm a huge Holley fan but you may want to be careful. Holleys have power valves that burn up during back-fires.....Qjets dont!
Usually, backfiring is an ignition issue(too much or too little advance) so I would suggest solving the backfiring before moving on to replacing the Qjet.
This pic is of a Q-jet that sat still for 10 years...then I sprayed it with carb cleaner...and it started right up...true story!
To Q jet rebuild or replace
