Russian Roulette
Old Jul 21, 2010 | 12:13 PM
battwins's Avatar
battwins
3rd Gear
Default Russian Roulette
My 1980, 305 ca edition, runs perfectly most of the time. However, when I turn it off with the a/c on it will not start, no click, lights come on but nothing happens. After 10 minutes or so it starts right back up. What Gives?
Old Jul 21, 2010 | 12:35 PM
Project80's Avatar
Project80
Starter heat soak? Are you running headers? The starter may not want to turn over until it cools off.
Old Jul 21, 2010 | 12:40 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Project80
...Starter heat soak?...
Sounds like it. Turning the ignition off with the AC on possibly isn't causing the problem.
Old Jul 21, 2010 | 12:48 PM
battwins's Avatar
battwins
3rd Gear
If I remeber to turn off the a/c before turning off the car it will start up. No headers, all stock.
Old Jul 21, 2010 | 01:03 PM
Project80's Avatar
Project80
My best guess with that situation is a voltage drop with the
ac switch being on.
Old Jul 21, 2010 | 01:13 PM
battwins's Avatar
battwins
3rd Gear
Any Idea on a fix? New Battery?
Old Jul 21, 2010 | 01:17 PM
Project80's Avatar
Project80
My first basic step would be to make sure all my battery, starter, AC wire harness connections were clean and tight.
Old Jul 21, 2010 | 01:27 PM
502Stingray's Avatar
502Stingray
Be sure to check your ground cable too, Ive had a very similar problem and it turned out the ground cable from the battery was corroded internally, the car would act very strangely with my electronics
Old Jul 21, 2010 | 01:52 PM
Project80's Avatar
Project80
That happens more than people think, it's best to use a digital volt meter and do a voltage drop test on the ground cable. More than a .5 volt drop is a concern.
Old Jul 21, 2010 | 02:01 PM
DZRick's Avatar
DZRick
I've had this happen with the positive cable in my truck.
To Russian Roulette
