327 block with small crack
Old Jul 21, 2010 | 06:20 PM
jobberone's Avatar
jobberone
jobberone
Default 327 block with small crack
I need to know if this crack in this 64 block is significant. It's at the rear of the block on the passenger side. It's less than an inch long on a circular boss with an 'insert' in it. It's at 9 oclock on the boss which is at 3 oclock on the back of the block. It appears to be 'old'.
If it's in a load bearing part of the engine and is significant, can it be repaired?
Appreciate any help I can get here. Thanks in advance.
I'm not getting the image to load from photobucket. Here's the url or link to the picture I took: http://s471.photobucket.com/albums/r...t=_DSC0001.jpg
Old Jul 21, 2010 | 06:30 PM
v2racing's Avatar
v2racing
That is the dowel pin hole used to align the bell housing. Unless you are drag racing it, I wouldn't worry too much about it. I would try and get the dowel out to where it will keep you bell housing in alignment while you tighten everything down.
Old Jul 21, 2010 | 06:32 PM
Will's'74VetteL-82's Avatar
Will's'74VetteL-82
I could be wrong but I dont think it would be a problem. Has it been run like that now or before?
Will
Now that i really look at it v2racing is correct , listen to what he said!
Old Jul 21, 2010 | 06:37 PM
Duke94's Avatar
Duke94
shouldn't be a problem.
Gary
Old Jul 21, 2010 | 07:31 PM
jobberone's Avatar
jobberone
jobberone
Thanks guys. And how did you get that pic to show up?
Old Jul 21, 2010 | 08:13 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Use the IMG line, not the direct link.
Old Jul 21, 2010 | 09:19 PM
Duke94's Avatar
Duke94
Right click on the IMG line and "copy", then "paste" it in your post. That's how I do it. May be other ways.
Gary
Old Jul 21, 2010 | 09:28 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
non critical area. it likely won't propagate.
Old Jul 22, 2010 | 07:27 AM
markdtn's Avatar
markdtn
Old Jul 22, 2010 | 08:26 AM
L88Plus's Avatar
L88Plus
I agree, it's an alignment hole, not critical, but with the right stresses in the right amount, it could grow. Before you drop it in the engine, drill a small hole just past where it looks like the crack ends. The rounded hole will stop the crack before it has a chance to cause trouble.
Old Jul 22, 2010 | 11:14 AM
Solid LT1's Avatar
Solid LT1
Find a local auto machine shop who has a "Lock n Stitch" repair kit, if you dont fix cracks in cast iron, they only get bigger over time. Other possibility is a powder torch repair, I would at least drill a hole with a drill motor into the end of the crack to keep it from spreading.
Old Jul 22, 2010 | 11:39 AM
hugie82's Avatar
hugie82
That's from guys at the machine shop spinning the Block on the concrete floor with the dowel pins in. I would try drilling a hole at the base of the crack if your not going to have it fix. Just a precaution to keep the crack from growing Shouldn't be a problem...
Old Jul 22, 2010 | 02:57 PM
Wrencher's Avatar
Wrencher
I agree that it will not be a problem. However, the dowel should stick out about a half inch, not flush as shown in your picture. It's important that the bellhousing line up correctly with the block to avoid vibration and/or seal issues, depending on what trans you run.
Hans
Old Jul 22, 2010 | 06:43 PM
08vycpe's Avatar
08vycpe
This is exactly correct. Cracks never get smaller they only get bigger. Enlarging the radius at the end of the crack will dissipate the stresses and the crack will not grow. A ball end mill would be ideal to get a spherical radius but a small drill point is the next best thing.
To 327 block with small crack
