U-joints
Old Jul 22, 2010 | 07:45 AM
Johan74's Avatar
Johan74
Default U-joints
Hello,
I'm installing new U-joints with grease fittings on both drive- and 1/2-shafts.
Wich direction should I put all grease fittings in order to make it the easiest to reach them with the grease gun?'
Thanks,
JOhan
Old Jul 22, 2010 | 08:41 AM
straub18045's Avatar
straub18045
get super duty ones without grease fitting, my recomendations. think either way should be able to get at it i think, play around and mock one up
Old Jul 22, 2010 | 08:57 AM
bashcraft's Avatar
bashcraft
Regardless of where the fitting is pointing, the area where the fitting hole is located, needs to be under compression, not tension when torque is applied. Either that or get the joints without grease fittings. They're stronger.
Old Jul 22, 2010 | 10:43 AM
Rally68's Avatar
Rally68
Spicer solids, for the half-shafts at least. Do a forum search for installation tips
Old Jul 22, 2010 | 12:13 PM
7T1vette's Avatar
7T1vette
You have to point the grease fitting toward the shaft in which it is installed. Otherwise, you will have it pointed toward a component (axle, tranny, wheel) such that you won't be able to get a grease gun to hook up to it.
As mentioned, if you have a 'beefed up' engine with significantly higher torque than stock, you probably want to go with joints without grease fittings. If you just cruise around and don't put lots of stress into those joints, pick whichever type you want.
Old Jul 22, 2010 | 03:46 PM
Johan74's Avatar
Johan74
Thanks!
/Johan
To U-joints
