Steering gear
Old Jul 22, 2010 | 03:00 PM
ED79's Avatar
ED79
Default Steering gear
Gear box is leaking at the pitman shaft seal and wormshaft seal. Can these 2 seals be replaced only or do I need a total rebuild or replacement? Stock 79, 350, automatic 76,000 miles ED
Old Jul 22, 2010 | 03:03 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
They can be replaced, but I'd check the cost of a rebuilt one. The difference in cost versus time may make it a better choice.
Old Jul 22, 2010 | 03:18 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
The gearbox should not leak anything since it should have thick grease
and not a liquid.
Old Jul 22, 2010 | 03:48 PM
ED79's Avatar
ED79
Advice taken, best suggestions where to buy? Ed
Old Jul 22, 2010 | 03:53 PM
ED79's Avatar
ED79
and not a liquid.
Well, it is thick but it leaks down and makes a mess on power steering system just tired of the leaks. Thanks Ed
Old Jul 22, 2010 | 05:33 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Corvette Steering Service in Anderson, SC
www.corvettesteering.com
I paid around $285 to rebuild my original, with a new rag joint
Freight both ways not included
You asked for best, not cheapest
Old Jul 22, 2010 | 06:28 PM
08vycpe's Avatar
08vycpe
A rebuild is probably not necessary. Before you spend the money, see if you can get proper adjustment following Jim Shea's papers.
The seals and bearings are very cheap and are available. If you take the gear out you can clean it up, do a visual inspection of the worm, check and set clearances and install new seals. There has been a lot of discussion about what grease to put in. It seems it's important not to use regular suspension grease as you need a special grease. Here is a pic of the part number for the correct grease recommended by some knowledgeable people from NCRS and others. I have it in my box.
Gary the steering gear guy got kicked off the forum for some reason but here is his email. He is very knowledgeable about these steering gears and can rebuild yours for you. He said it's o.k. to give out his email so feel free to contact him. He can also be found on the NCRS site.
Gary.RAMADEI@radiall.com
Old Jul 23, 2010 | 09:19 AM
ED79's Avatar
ED79
Options for removing pitman arm since I don't have this J-6632 tool?
Old Jul 23, 2010 | 09:25 AM
bruiser's Avatar
bruiser
St. Jude Donor '15
AutoZone has pitman arm puller that you can rent for free.
I broke 2 pullers from Harbor Freight trying to get mine off.
Old Jul 23, 2010 | 10:38 AM
ED79's Avatar
ED79
Sounds like a deal to me thanks Ed
Old Jul 24, 2010 | 11:30 AM
ED79's Avatar
ED79
Well, since there is some leakage would this make the steering a little harder? Ed
Old Jul 24, 2010 | 08:41 PM
Richard Cooper's Avatar
Richard Cooper
ED79,
I sent my steering gear box to Yougi Bairs Corvettes. They rebuilt the whole thing and sent it back to me in a very short period of time. They did an excellent job on the box and even painted the whole thing. When they recieved the box they called me to let me know they got it and let me know when they shipped it back. I do not remember the price but it was good.
Old Jul 25, 2010 | 11:32 AM
Frankenvette's Avatar
Frankenvette
Originally Posted by corvettesRbest
Dude
This is the guy that did mine, Fantastic job.
http://www.digitalcorvettes.com/foru...ad.php?t=76773
ED79,
We have 3 things in common. We both have C3 vettes, live in Asheville and have leaking grease around the steering box seals. I've replaced the seals at least once but plan to have the steering box inspected for worn internal parts when I pull it to fix the leak. I'm sure there are multiple vendors who can rebuild your box, but I agree with the post quoted here. Gary,GTR1999, has a great reputation on several boards for his work. I've spoken to him on several occassions as an informational resource. When I pull my steering box I plan to send it to him. That way I know it's been done right.
Jim
To Steering gear
