Windshield trim gap?
Old Jul 23, 2010 | 02:28 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default Windshield trim gap?
I have a gap on the windshield trim (outer) at the top, on the passenger side, about 1/2"
Is there supposed to be any gap, if not, how do I go about fixing it?
Old Jul 23, 2010 | 02:35 PM
BBCorv70's Avatar
BBCorv70
Doesn't sound normal. Can you post a photo of the problem?
Old Jul 23, 2010 | 03:58 PM
Alan 71's Avatar
Alan 71
Hi ms,
I agree with bb that some pictures would help.
The trim was tight against the glass originally.
The new glass needs to be the proper thickness (SOME replacement glass is thinner), the glass needs to be spaced away from the windshield frame the proper amount, and the trim and clips must be in good shape so the trim goes on properly.
As you can see a LOT of things need to be done properly to get a nice tight fit.
Pictures?
Regards,
Alan
Old Jul 24, 2010 | 10:29 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Old Jul 24, 2010 | 10:31 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
It's a sunny day, any other pics you think would be helpful??
Old Jul 24, 2010 | 10:37 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
How much room do you have on the driver side? If you remove the side trim and then the top trim you may be able to move the molding over enough to hide this.
Old Jul 24, 2010 | 10:55 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
I'll have a look.
Old Jul 24, 2010 | 12:30 PM
Alan 71's Avatar
Alan 71
Hi m,
It looks to me like the rear tabs on the long thin piece of SS trim aren't slid down into the trim clips properly, which has put a severe bend in the long piece of trim.
The ends of the long piece needs to be able to slide UNDER the SS trim on the a-pillar
Compare it's shape to the same piece in my picture.
Regards,
Alan
Old Jul 24, 2010 | 05:40 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
[IMG=http://a.imageshack.us/img135/2509/img0516y.jpg][/IMG]
Old Jul 24, 2010 | 05:51 PM
noonie's Avatar
noonie
the molding is just not centered on the frame, needs to be moved to the pass side.
Repair could get involved, maybe find a better one, good project if you don't drive in the winter.
Old Jul 24, 2010 | 06:23 PM
Alan 71's Avatar
Alan 71
Hi,
I agree that the ss strip needs to be slid to the right side but the tabs on the back of the piece are in FRONT of the clips not IN the clips. That's caused the gap between the large SS header trim and the long SS trim. It only needs to go back about 1/8", but that will allow it to fit normally.
Regards,
Alan
Old Jul 24, 2010 | 07:15 PM
0Willcox Corvette
Former Vendor
Alan, Noonie and Moon...
I copied his top picture and blew it up.. if you do this and look real close there is only about 1/8" of the molding under the driver side. I don't think he's going to have room to slide it over. It does look like the molding is not on the header clips, but it also appears as if someone may have cut the passenger side of the molding off. No telling for sure as both you know.
The upper windshield molding has tabs on it to retain in the clip and I wonder if these tabs are not bent. Either way, the top molding should butt up pretty close to the upper top molding and you should not have that huge gap in there.
My advice would be to remove the pillar side moldings, and the header and see what's going on. To slide the upper molding over you need to remove the side pillars anyway and once you have them off the upper can be pulled off and repositioned easily if needed.
The uppers can be found used in decent condition
Old Jul 24, 2010 | 07:24 PM
noonie's Avatar
noonie
To me, it looks like it's held on with double sided tape.
Old Jul 25, 2010 | 10:17 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
I popped the top trim piece off and moved it over towards the passenger side.
It's not a perfect fit, but it's much better than it was before.
Do I bend the tabs to get it to fit closer to the t-top moldings?
Old Jul 25, 2010 | 11:33 AM
Alan 71's Avatar
Alan 71
Hi MS,
As I posted, you need to make sure the tabs are going IN the clips not IN FRONT of them.
If the tabs are in front of the clips it causes the gap between the front of the header ss trim and the back of the long thin ss trim piece.
It's very hard to see were the tabs are going if there is a lot of gunk and sealer around the clips.
Regards,
Alan
Old Jul 26, 2010 | 10:31 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
I did make sure they were in the clips.
Can the clips be moved backwards at all?
If not, do I just fill that gap with RTV, or is there are more elegant solution?
Old Jul 26, 2010 | 04:36 PM
Alan 71's Avatar
Alan 71
Hi MS,
There should be very little gap. Maybe 1/64".
St. Louis used a silver colored 'caulk' in the gap. It went on quite soft, almost like a thick liquid and set up quite hard.
I used Squibbles 3d fabric paint from the craft's store. It comes in a small soft plastic bottle with a fine tipped nozzle that lets you squeeze it out in a fine bead. I put a bead in place and then smoothed it with my finger like you do with bathtub caulk. I used Iridescent Silver.
Regards,
Alan
Old Jul 27, 2010 | 10:08 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Thanks for the tip, I'll look at what's available and fill in the gap.
Old Jul 27, 2010 | 08:40 PM
Timsride's Avatar
Timsride
Nice job I really like how that finishes it off. I looked at the pic before I read Your reply and thought You had somehow set Yours beyond perfect.
Originally Posted by Alan 71
Hi MS,
Regards,
Alan
To Windshield trim gap?
