700r4 transmission Q!
Appreciate any help, thanks Neil.
Other than that, your cooler line will work, you will need to shorten your drive shaft about 3 in. and relocate the parking brake cable wheel. Lastly, you will have to modify, or purchace the bracket that the 350 trans sits on. You do not need a new crossmember.
You will like the swap.
the only computer part of the 700 is the lockup, but inside the unit there is a 4th gear switch...that locks the converter in 4th gear only....
so you only need supply +12 switched voltage to the 4 pin connector on the driver's side apron....
see the ATSG service manual for the wiring/instructions....
there are a ton of upgrades for it, and I recommend the torrington sun shell.....BRUTE....
Oh, edit....the kickdown is fairly easy to mount and adjust, make sure it's on the snug side, that's about it.....if shifts are too late or violent for you, relax the cable a tad....
http://bowtieoverdrives.com/catalog/...php?ITEMID=332
the wiring harness white square plug there, comes from junkyards, just cut plenty of wire with it....typically free, here....
I wire it with a BWD S870 brake light switch, in place of the stock one, but has a switch that OPENS the ign sw controlled +12 feed line to the tranny, when the brakes are pressed.....the lockup control is off the internal wiring to the pressure switches in 4th gear, maybe 2-3 also, depending....
wiring is not my strong suit so i am really confused
