GMPP Serpentine kit: Alternator question (please help)
Old Jul 25, 2010 | 05:42 PM
James B's Avatar
James B
Default GMPP Serpentine kit: Alternator question (please help)
Hey guys, I have a question regarding the wireing diagram for the alternator on the GMPP Serpentine kit. I have read a couple of threads from durango boy, and understand which wires go where, but my question is with regards to the 50 ohm resister in the diagram.
Question:
Do I need to add this resistor into my wiring circut, or is this resister built into my gauge that is in the center gauge cluster? I am afraid that my alternator will not charge correctly if I do not have this resistor.
Here is the diagram:
Thanks for the help!
Old Jul 25, 2010 | 06:36 PM
SIXFOOTER's Avatar
SIXFOOTER
you use either the resistor, or the light bulb (GEN light)
you should have a GEN light in the dash, so you will not need the resistor, just hook everything up as it was before.
Old Jul 25, 2010 | 06:39 PM
SteveG75's Avatar
SteveG75
Depending on the year, you need the resistor. My '75 does not have a GEN light (not all C3's had them) so I needed the resistor.
There is a SI-CS conversion harness that has the resistor built in. I got mine at NAPA. Makes the job nice and easy.
Old Jul 25, 2010 | 07:03 PM
James B's Avatar
James B
My car is a 73 and does not have a generator light.
I ran another search and found this CS Alternator paper by durango boy:
http://photos.imageevent.com/durango...%20Install.pdf
It answered my question regarding the resistor. Since I do not have the generator light I can use part number EC82 from napa which has a built in resistor to the wiring plug.
Old Jul 25, 2010 | 09:56 PM
SIXFOOTER's Avatar
SIXFOOTER
DB Usually did pretty good research
To GMPP Serpentine kit: Alternator question (please help)
