Intake Manifold Recommendations
Old Jul 26, 2010 | 05:01 PM
C3 Rob's Avatar
C3 Rob
6th Gear
Default Intake Manifold Recommendations
I am rookie to the site so I am apologizing in advance if I am doing this wrong or in the wrong area.
I have a 70 small block car that I am assembling a nice stroker motor for, it has the factory LT-1/Big Block hood. My question is what manifold can I run under the factory hood? I like the Performer RPM Air Gap will it fit? If not does anybody have a recommendation that would work well on a stroker motor?
Rob
Old Jul 26, 2010 | 06:06 PM
pauldana's Avatar
pauldana
Rob
it will probably fit, but you need to match the intake with the cam and heads and more.... but first of all, what about the cam? what are the specs?
Old Jul 26, 2010 | 06:24 PM
ZZ71S's Avatar
ZZ71S
Is the hood a L88 bb hood
Old Jul 26, 2010 | 08:16 PM
Rebelrob's Avatar
Rebelrob
Might be what your looking for. Can't go wrong with the airgap....
http://forums.corvetteforum.com/c3-t...irgap-fit.html
Old Jul 27, 2010 | 11:33 AM
C3 Rob's Avatar
C3 Rob
6th Gear
I have the standard OEM big block hood - not the L88 style.
Old Jul 27, 2010 | 11:36 AM
C3 Rob's Avatar
C3 Rob
6th Gear
I have not nailed down the cam yet, my intake choice is going to effect which cam (RPM range) I can go with. If the RPM Air Gap fits, I might go with Edelbrock's matching cam that they offer in roller version. I had great luck with that cam in my 350 Camaro.
Old Jul 27, 2010 | 01:04 PM
pauldana's Avatar
pauldana
im running the RPM and the roller RPM cam and it is a great combination go roller though.... dont even think about anything else... flat tappet cost me a new build at ~800 miles..
i dont know about the big block clearance, but i wish you luck... Paul
Old Jul 28, 2010 | 01:57 PM
C3 Rob's Avatar
C3 Rob
6th Gear
Thank everybody for the information. Sounds like I can go with the RPM Air Gap with a drop base air cleaner!
To Intake Manifold Recommendations
