Clutch Diameter
Old Jul 27, 2010 | 05:12 PM
jtramont's Avatar
jtramont
Default Clutch Diameter
Hi folks...probably a novice (aka dumb) question here but...
I am going to need to replace the clutch in my '73 (L82 engine) and in looking around, I see that I should have a 26 spline/1 1/8" input shaft (I think).
My question is about the diameter of the clutch plate. I've seen 11", 10.5" & 10.4". How do I know what diameter clutch plate to go for?
Old Jul 27, 2010 | 06:15 PM
Solid LT1's Avatar
Solid LT1
If your Vette is still stock the L-82 came with an 11" diameter clutch.
Old Jul 28, 2010 | 10:17 AM
jtramont's Avatar
jtramont
So were the smaller diameter for the L48?
Old Jul 28, 2010 | 01:07 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Look at the starter - if it is a stock type starter and has inline bolts (two different lengths) to the block, you have the small flywheel and it uses a 10.4" (or 10.5") clutch. If the bolts are staggered (both same length), it uses a large flywheel which uses an 11" clutch.
Old Jul 28, 2010 | 01:43 PM
jtramont's Avatar
jtramont
Excellent...thanks!
Old Jul 28, 2010 | 04:02 PM
jordan89's Avatar
jordan89
Old Jul 29, 2010 | 05:48 AM
73StreetRace's Avatar
73StreetRace
I have a staggered pattern starter, 168 tooth flywheel and a 11" clutch on my '73 L-82
Old Jul 29, 2010 | 06:51 AM
CFD E59's Avatar
CFD E59
To Clutch Diameter
