I caught the thread for adjusting speed settings at the transducer, not sure if this can apply to mine. ( hope so )
With the cruise set, going up a hill the cruise will lag back 5-7 mph before kicking in and then run at least 10 mph faster before settling back to setting . Is this normal or will the adjustments for the above thread also fix this? Thanks Ed
On the transducer you can try to adjust the tube on the left side which moves the green tube in or out.
Loosen the nut and adjust out 1 turn. You may have to experiment with the adjustment in or out until it works better.
Man I missed this thread, it was another one. Sorry for the trouble and thanks for the info. When the weather breaks I'll give it a try.
Thanks again to bruiser & 7T1 Ed
