Brake pad trick
Old Aug 3, 2010 | 12:55 PM
omegac1's Avatar
omegac1
Default Brake pad trick
I am changing my brake pads for the first time...new to me C3. Is there a way to install the new pads without removing the caliper. The manual talks about pushing back the pistons with some tool. I cant get any tool like two screw drivers in there and stick the new pad in at the same time. Am I missing the trick?
Old Aug 3, 2010 | 01:16 PM
Timsride's Avatar
Timsride
Im not sure that You can get the brake pads out without removing at least one caliper bolt then rotating the caliper upwards to clear rotor. The problem will be that the brakes always have a slight bit of pressure on them so they will always want to close slightly making it slightly difficult to hold them open enough to slip over rotor.
Old Aug 3, 2010 | 01:23 PM
Peterbuilt's Avatar
Peterbuilt
There is a tool but I don't own it, I just pull the caliper install the pads and reinstall. It goes pretty quickly.
Old Aug 3, 2010 | 01:57 PM
Woodsters's Avatar
Woodsters
Originally Posted by petes74ttop
...I just pull the caliper install the pads and reinstall. It goes pretty quickly.
Yeah... what he said. Just pull the caliper and replace the pads. It's not a tough job but it will take some work due to the "slight bit of pressure".
Old Aug 3, 2010 | 02:18 PM
...Roger...'s Avatar
...Roger...
I have the tool but some guys say they use a wide putty knife bent to about 45 degrees to hold the pistons back.
Old Aug 3, 2010 | 03:18 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
It's easy if you have a wide putty knife (~5"). Just pull the pin and pull the first pad out. Before the pistons close the gap to the rotor, push the putty knife in to hold the pistons back and then insert the new pad between the putty knife and the rotor. The new pad will wedge the putty knife towards the pistons and drop right in. Repeat on the other side.
Note: If the old pads were really thin, the push back of the pistons may cause some brake fluid to overflow the MC reservoir. It will help to pull some fluid out of the MC down about 3/4" from the top of the MC before doing this.
Old Aug 3, 2010 | 04:52 PM
hooperdoski's Avatar
hooperdoski
Default A trick
I pull the calipers like others because it's easier. However, when I'm pulling the calipers I pull them about a 1/2 inch up and with a dial indicator I measure the distance between the pads. Once measured I pull the calipers off and change out the pads. I then cut a 1X4 block of wood to 3" long and a little wider (0.010") than the distance I measured between the pads and use this block to hold the pads open while I slip the caliper over the rotor. The rotor pushes the block out as the calipers are lowered. The block has worked great on all the disk pad jobs I've done.
Old Aug 3, 2010 | 06:57 PM
terry82's Avatar
terry82
this is what i use but i did make my own with spring metal.http://www.mamotorworks.com/corvette...arched=602-980
Old Aug 3, 2010 | 07:45 PM
Fuelie74's Avatar
Fuelie74
Why on earth would you pull the calipers to change the pads? They load from the top. Just pull the pin and slide them out.
To put them back in a keep a piece of sheet metal around that's about the same width as the pads and about 4 inches high. I just slide it in pull the pistons back and slide the pads in.
If you need a tool to push the pistons back on your C3 Vette, then it's time for new calipers!
Old Aug 4, 2010 | 12:28 AM
vettehardt's Avatar
vettehardt
I use someting simmilar to the tool that terry82 linked too. You slide that down between the piston and pad. You then pull the pad out and the piston will stay where it is. You then slide the new pad in.
I have also used a small prybar (screwdriver) to push the old pad against the pistons untill they were all the way in. I can then pull the old pad out and slip the new pad in before the pistons push out too far.
Rember to push the pistons in straight. If they get cocked they can mess up the bore and it will cause a leak.
Old Aug 4, 2010 | 06:45 AM
7T1vette's Avatar
7T1vette
If you have a lot of pad wear, pushing the pistons back in the caliper (in order to make room for the new, thicker pad) can back-fill the master cylinder. Make sure that there is "room" for the fluid or use a turkey baster [or whatever] to remove some fluid so there is no spill-over when the M/C cover is removed.
Old Aug 4, 2010 | 09:46 AM
Paul L's Avatar
Paul L
Just for reference this is the tool but the putty knife method works very well.
Old Aug 4, 2010 | 01:37 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by terry82
Same here. Caliper Clipper. I have a pair of them.
Brake pads can be changed without removing the calipers.
Old Aug 4, 2010 | 02:05 PM
toddalin's Avatar
toddalin
If for whatever reason you do pull the calipers, I load the pads in place and put an appropriate sized socket between them to hold them in place. Then as you put the calipers into place, the socket simply rolls out from the pressure against the rotor.
Old Aug 4, 2010 | 02:54 PM
929nitro's Avatar
929nitro
Made the job very easy. No need to pull caliper.
To Brake pad trick
