Rear main seal time
Good luck!
Take a good look at the lower main bearing while you can. It will give you a boat load of information regarding the condition of your engine,
Depending on the condition of the bearings and the mileage, might change the oil pump while the bottom is opened up.
If you can see the bottom of the pan, run a magnet near the bottom of the pan and see if any shavings stand up. If not, that's a good thing.
Spend plenty of time when buttoning it up. Get in a hurry and you'll have another thread regarding an oil pan leaking.
good luck.
Ed
Felpro makes a grey rear seal ( cheaper ) and a nitron type ( much better ) that is
brown in color. Offset the seal 3/8 of an inch, use no sealer, and you will
be very happy. Done 3 recently with not a drop of oil to leak afterwards. Just my humble opinion.
The steering gear has to come down as well.
In short here is what I did;
Drain the oil, disconnect idler arm at the fframe and move asidee to drop the oil pan on the 68, unbolt and drop the pan, (I didnt need to remove the starter or anything else), remove the oil pump, remove the main cap (may need a gentle tap to losten) I also loosened but did not remove the next cap for easier seal install, remove the seal and clean the area with brake cleaner,oil the seal (not the ends of the seal)and CAREFULLY install both halves of the new seal leaving 1/4 to 3/8 offset , put a small amount of RTV (I used Permatex Ultra Copper High Temp RTV Silicone) on teh mateing surface (look at Paul 74 picture above where it says oil seal compound), put some assembly lube on the cap without getting it on the RTV and reinstall, torque to spec. Reinstall the oil pump.
I used the felpro one piece oil pan gasket with a little blue RTV at the corners. It's much easier to use than the 4 piece gasket when the engine in in the car. I let mine sit overnight to give the RTV a chance to set up. I haven't seen a drop of oil since.
Oh yea, don't try to drive it till you re-connect the idler arm !
