76 cal emissions
Old Aug 5, 2010 | 12:17 AM
TheBigDogg's Avatar
TheBigDogg
Navigator
Default 76 cal emissions
ok, I have searched and searched, I can't find a thread to help me find what exactly I need for california emissions.
the production date is 8/75
can anyone help me?
this is what is under the hood right now, there is no vacume line diagram either:
I looked up the casing number here: http://www.nastyz28.com/sbchevy/sblock.php
it says it was for a car, truck, and vette from 69-79
thanks,
Harry
Old Aug 5, 2010 | 12:55 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Mine came with pcv valve, efe valve, evap cannister, egr and of course the preheated air cleaner (tube from the exhaust manifold).
Old Aug 5, 2010 | 01:00 AM
TheBigDogg's Avatar
TheBigDogg
Navigator
no smog pump?
Old Aug 5, 2010 | 03:20 PM
TheBigDogg's Avatar
TheBigDogg
Navigator
anyone know where i can find a schematic for the vacume lines, or pics
Old Aug 5, 2010 | 03:41 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Purchase the 76 assembly instruction manual (AIM). It'll prove to be handy. It's possible the California emissions certification did not require any additional equipment added on the asssembly line.
The two numbers stamped on the pad on the block at the front of the right head will identify the engine and show a VIN deriviative of the vehicle the engine was originall installed in.
Valves covers and carb are aftermarket.
FWIW: August 75 was the first month of production for the 76 models; that would make your car an early one.
Old Aug 5, 2010 | 04:54 PM
Snoopysvet's Avatar
Snoopysvet
Originally Posted by TheBigDogg
no smog pump?
Did L-48 have smog pumps?
Do you have to smog it?
I don't claim to know the law but check this out
(g) For purposes of subdivision (a), any collector motor vehicle,
as defined in Section 259, is exempt from those portions of the test
required by subdivision (f) of Section 44012 of the Health and Safety
Code, if the collector motor vehicle meets all of the following
criteria:
(1) Submission of proof that the motor vehicle is insured as a
collector motor vehicle, as shall be required by regulation of the
bureau.
(2) The motor vehicle is at least 35 model-years old.
(3) The motor vehicle complies with the exhaust emissions
standards for that motor vehicle's class and model year as prescribed
by the department, and the motor vehicle passes a functional
inspection of the fuel cap and a visual inspection for liquid fuel
leaks.
AB 2683
http://info.sen.ca.gov/pub/03-04/bil...chaptered.html
Old Aug 5, 2010 | 05:08 PM
TheBigDogg's Avatar
TheBigDogg
Navigator
I was going to try and search those numbers today
here is what is staped there:
small stamp: 16S400143
larger stamp: V08O7CKX
anyone know what those are?
Old Aug 5, 2010 | 05:28 PM
TheBigDogg's Avatar
TheBigDogg
Navigator
ok, so i figured this out, the small #'s are part of the vin, and it matches my vin so the block is the original
V=Flint
08= August
07= 7th day
CKX= 1976 350 a/t L L48 180hp 4bbl Vette
found the info here: http://www.nastyz28.com/chevy-engine-code-stampings.php
Old Aug 5, 2010 | 06:33 PM
fauxrs's Avatar
fauxrs
criteria:
bureau.
leaks.
AB 2683
That code does not exempt the car from the tailpipe sniffer test, it does however exempt the car from visual and functional tests of the emissions equipment persuant to
Section 44012 (f) A visual or functional check is made of emission control
devices specified by the department, including the catalytic
converter in those instances in which the department determines it to
be necessary to meet the findings of Section 44001. The visual or
functional check shall be performed in accordance with procedures
prescribed by the department.
So if your car can pass the sniffer test without the underhood emissions gear and meets the requirements of being a collector motor vehicle then you would be in good shape.
I am reasonably sure that only a L-48 vette sold in CA. would have the smog pump, all would have EGR, EFE, PCV, EVAP, CAT, charcoal cannister.
Old Aug 6, 2010 | 12:35 PM
Easy Mike's Avatar
Easy Mike
...ok, so i figured this out, the small #'s are part of the vin, and it matches my vin so the block is the original...
Correct. Congratulations.
...08= August 07= 7th day...
I told you your car was early. Engine was assembled at Flint on August 7th; it was then shipped to St. Louis where it was received and stockpiled before your car was assembled.
The Time/Build date in the upper right corner of the trim tag on the driver's door hinge post will tell you the day your car passed the point on the assembly line where the tag was attached. Your date will be Axx with A standing for the first month of production (August for the 1976 model year) and xx standing for the date. Your code will be after August 7th.
To 76 cal emissions
