Tada! Its done!
Old Mar 26, 2002 | 01:34 PM
Black68Vette's Avatar
Black68Vette
Default Tada! Its done!
Well, thanks to the help of the great people here, and at VB&P, the front transverse mono spring is installed.
Before
larger
http://temp.corvetteforum.net/c3/bla...tte/before.jpg
After
larger
http://temp.corvetteforum.net/c3/black68vette/after.jpg
Thanks again for all your help! I still have to toss the tires on and adjust the height, but the rough part is all done!
Old Mar 26, 2002 | 01:37 PM
Square's Avatar
Square
Default Re: Tada! Its done! (Black68Vette)
cool! What are the advantages of making this change? (I'm clueless about this suspension stuff)
Old Mar 26, 2002 | 01:40 PM
Black68Vette
Default Re: Tada! Its done! (Square)
Pretty much it puts the C4/C5 style front type suspension on. Major plusses are adjustable spring rate from 300-700lbs! and ride height can be adjusted either way by around an inch and a half, all rapidly. Plus it helps cornering signifcantly, I've heard skidpad numbers from .95 to over 1g with it and a bunch of other goodies on the back too.
Old Mar 26, 2002 | 01:54 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
:cool: :cheers:
Stewart's74's Avatar
Stewart's74
Looks Great :cheers:
I can look at before and after pics all day. They really give you a sense of accomplishment.
Stew
Old Mar 26, 2002 | 01:55 PM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Looks like you lost some weaght with that set up who makes it and how much?
Old Mar 26, 2002 | 02:02 PM
Black68Vette
Default Re: Tada! Its done! (Wightnite)
Its Vette Brakes + Products
http://www.vettebrakes.com/
Around $650-700 with new balljoints. Probably need new shocks too after, as the fiberglass spring acts differently than steel.
To Tada! Its done!
