Borg Warner T-10
Old Aug 7, 2010 | 08:03 PM
Phil Zell's Avatar
Phil Zell
Default Borg Warner T-10
1976, How can you tell if the T-10 in a 76 is close or wide ratio? Input shaft is fine spline with 2 grooves.
Old Aug 8, 2010 | 08:32 AM
Phil Zell's Avatar
Phil Zell
bump
Old Aug 8, 2010 | 11:17 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I did a couple of seaches. Couldn't find anything useful on the number of grooves but did find some useful info on this post:
http://forums.corvetteforum.com/c1-a...ranny-i-d.html
Old Aug 8, 2010 | 12:10 PM
bluthundr's Avatar
bluthundr
According to the books I have, the 76 standard ratio first gear is 2.64:1 and the close ratio is 2.43:1. So, if you have it disconnected from the engine or out, put it in first, mark the input shaft, and spin the tailshaft. If you get less than 2.5 revolutions, it's a close ratio, if you get more it's a standard ratio.
Old Aug 8, 2010 | 04:38 PM
Phil Zell's Avatar
Phil Zell
Thanks all
Much appreciated
Old Aug 8, 2010 | 04:44 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Two grooves is the 2.43 gear ratio set; 3 grooves is the 2.64 set. For a good source of information, go to the following:
http://pontiacpower.org/BW.htm
Old Aug 8, 2010 | 07:42 PM
L88Plus's Avatar
L88Plus
larrywalk, thank you sooooo much for posting that link. I had it saved on an old computer that crashed and have done a ton of searches trying to find it.
I have one with 4 grooves but I can't see any dimples in the gears that would indicate it is a nickel geared piece. I'm hoping it is, looks like I may be selling it in favor of a TKO-600.
Old Sep 6, 2010 | 08:29 PM
RustyBus's Avatar
RustyBus
which T 10 is better or more prefered ?
Old Sep 7, 2010 | 10:12 AM
20mercury's Avatar
20mercury
Default D&L transmission link
http://www.dandltransmission.com/borgratio.html
Here is a good one that I found.
2 groove is the close ratio. Agree the best way is to put it in gear and count rotations.
To Borg Warner T-10
