Trying to set my total timing
Old Aug 8, 2010 | 02:49 PM
theesir's Avatar
theesir
Default Trying to set my total timing
Following the pinned instructions up top and have read the associated articles.
I have set my initial timing to 0 degrees. I have a 350, 300 hp and that is the base timing in my manual. When I go to check my full timing, I am setting my timing gun to 36 degrees and the timing mark ends up on the bottom of the engine. Revving the engine brings the line to be pointing straight at the passenger side firewall. I have to set the timing to 58 degrees on the gun so that I can rev the engine and get the line back to the zero mark and when I do this the timing mark is coming over the top of the motor (as opposed to from underneath toward the driver side... is this the direction I should be seeing it go?)
What is going on here???? With the base timing set at 0 or even 4 degrees the car runs (and drives) great.
How is that I am running advanced by an extra 20 some degrees or am I not.. rather I'm just doing something wrong.
Help!
Old Aug 8, 2010 | 03:24 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Timing an engine is a simple basic procedure. I've having difficulty figuring out WTH you're experiencing. I'd suggest getting a timing tape for your harmonic damper, and you can then rule out errors coming form your adjustable timing light.
I'm not trying to insult you or anything, but hopefully you have the timing light attached to #1 cylinder and not #2 cylinder.
Old Aug 8, 2010 | 03:31 PM
BKbroiler's Avatar
BKbroiler
Are you disconnecting the vacuum advance while you're checking the timing? You should be. If not, you might read 58 total, including vacuum.
Old Aug 8, 2010 | 03:42 PM
theesir's Avatar
theesir
No offense taken. I am indeed on the #1 wire, which is attached to the #1 cylinder. My gun seems to be working OK. Just for confirmation... I have set my initial timing to 4 degrees. When I set the gun to 4 degrees the timing is on the TDC mark, if I set the gun to 0 degrees, the timing mark moves to the 4 degrees before TDC mark.
As I turn the timing on the gun to 36 degrees the timing mark moves down past the TDC mark and ends up near the bottom of the motor. The instructions on setting total timing say to increase the engine RPMs until the timing line stops moving and that should be at or near the TDC mark. For me, the timing line is no where NEAR the timing markers.
Old Aug 8, 2010 | 03:43 PM
theesir's Avatar
theesir
Yes, vacuum advance disconnected and vacuum line plugged.
Old Aug 8, 2010 | 10:13 PM
'75's Avatar
'75
Does your timing light have a setting for 2 or 4 cycle?
Old Aug 8, 2010 | 10:49 PM
lars's Avatar
lars
With the vacuum advance hose pulled off, rev the engine until the advance no longer advances any further and adjust your timing light so that the timing mark aligns with "0" on the tab. What reading do you get on the gun?
Lars
Old Aug 9, 2010 | 07:39 AM
theesir's Avatar
theesir
Lars
About 58 degrees
Old Aug 9, 2010 | 08:03 AM
gkull's Avatar
gkull
What Lars is trying to point out is: rev your motor to 3500 and hold the rpm steady. If you are reading 58 total with the vacuum advance disconnected loosen the dist. and turn it down to @ 38 degrees.
Initial advance can NOT be changed. It is what it is unless you change the dist. advance curve.
Old Aug 9, 2010 | 10:09 AM
lars's Avatar
lars
If your timing advances from 4 degrees at idle to 58 degrees max centrifugal, you have a defective distributor which allows 54 degrees of centrifugal advance. You need to fix the distributor.
Lars
Old Aug 11, 2010 | 03:22 PM
wolflt1's Avatar
wolflt1
hi
sorry to hijack in part the thread.
what are the numbers for a 70 lt-1?
idle speed? max advance? initial advance, etc.
i suppose setting up the ignition advance will be the same with the vacuum advance blocked. should the centrifugal advance be disabled also?
thanks
To Trying to set my total timing
