ceramic coated headers
Old Aug 12, 2010 | 06:40 PM
rugerm44's Avatar
rugerm44
Default ceramic coated headers
Dose the ceramic coating help much with under hood heat?I have tried the wrap but rusted out headers in just a couple of years but that car was driven every day.Im thinking the heat is frying everything under the hood including my ps control valve.The car had them when I bought it.I may just get some repro exhaust manifolds and call it quits with the headers.I dont drive it more than 2000 miles a year but its roasting everything under the hood.
Old Aug 12, 2010 | 07:47 PM
63vert's Avatar
63vert
I had my headers ceramic coated a few years ago, the place that did the work polished and coated them inside and out. It does cut down on the heat under the hood plus when they polish the aluminum oxide in the ceramic, it looks pretty good and stays that way with little effort. I wouldn't buy anther set that wasn't coated
Old Aug 12, 2010 | 08:38 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
There's a noticeble difference. I had my headers coated (inside and out) several years ago. They still look great. I had forgotten how well the coatings worked until last year when I had to modify the header (I welded in a new #1 cylinder tube to clear the new suspension). For initial cosmetics I put a temporary high temperature silver spray paint coat on the new tube. There's a very obvious difference in the amount of radiated heat coming off the #1 tube versus the rest of the tubes.
Old Aug 12, 2010 | 09:03 PM
rugerm44's Avatar
rugerm44
Right now the header tubes are around 600 deg.If it would cut it in half it would be worth it.
Old Aug 12, 2010 | 10:23 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Do you think a coating made of anything other than ice cubes would cut the temps in half ?
To ceramic coated headers
