Question for Mountainmotor?
My bad,I went to your page and saw where you have the XE 268.With the 3.08 gear you have and automatic transmission that is a pretty good cam choice.I know you do not want headers but that will yield your largest gain or improvement.
For what it is worth here is what I would have done in your situation while buying parts
Comp XM 270H cam
A $90.00 Alabama brand 2000 stall converter
A nice set of headers with the thick flanges
A modded q-jet from a shop like Jet or The Carb Shop
Still though your cam will work well after carb is tuned properly.
I think if you were to get in touch with either of those companies and tell them what you have they would be more than willing to sell you the correct hangers and rods for your combination.Although a idle circuit rework might be in order for optimum results.You might call them and see what they think about your carb/motor combination.I think you would be surprised how a "worked" q jet will perform and how much smoother the idle will be.
Everything is a compromise on a street car.Headers really pick up the performance of a Big Block Chevy though.Gas mileage as well in motor combination like yours .I would lean in that direction as well as towards the purchase of carb parts through one of the above companies.
Hope this helps to some extent.
[Modified by mountainmotor, 1:23 PM 3/27/2002]
P.S. I have a M20 four speed. :eek:
Anyway I am going to contact the carb shops that you mentioned to see if I can get some additional performance out of my Edelbrock 1901.
I know that headers would be an improvement, but I'm not ready to
make that move right now. :cheers:
