Cold startup issue
Old Aug 14, 2010 | 11:14 PM
Ethan1's Avatar
Ethan1
Default Cold startup issue
My friend has a '74 L82 Corvette and has been having a problem with it on cold startup. I guess from what he told me, when starting up, choke closes and then starts. But, when he gives it gas, there is a hesitation. When warmed up, it runs perfectly fine. I gave him a nother Qjet w/ electric choke and it does the same thing. Could it be timing? Any suggestions are helpful.
Thanks,
Ethan
Old Aug 15, 2010 | 01:24 AM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
It is normal for a carburated engine to have hesitation for the first minute or two, how cold a cold start are we talking, the car should run fine after about two minutes of driving!
Old Aug 15, 2010 | 09:21 AM
Paul L's Avatar
Paul L
They do stumble when cold. I would say what you have described is normal. We can become spoiled by the cold driveability of modern fuel-injected cars.
Old Aug 15, 2010 | 10:45 AM
7T1vette's Avatar
7T1vette
The carb and choke adjustments need to be reset according to the Chevrolet Chassis Service Manual instructions in the "Fuel System" section [6M].
Old Aug 15, 2010 | 10:55 AM
fishfryer's Avatar
fishfryer
Maybe the ignition system is a little weak too, but if it runs good after a few minutes, then I wouldn't worry too much.
Old Aug 15, 2010 | 06:41 PM
Rich's'78's Avatar
Rich's'78
When the choke is properly set up, the car will run fine until hot. Mine does! There is more than just choke plate opening rate to to get the right balance with the fast idle setting.
Old Aug 15, 2010 | 07:49 PM
PeteZO6's Avatar
PeteZO6
TOO. When I had the stock setup on my '69 which I drove 132,000 miles, I don't recall ever having a drivability problem when cold or hot. At least not when it had a fresh tune. Now my current setup with no heat to the crossover, is another matter. I have to be careful with the throttle until the engine is warm.
Pete
Old Aug 15, 2010 | 07:53 PM
Paul L's Avatar
Paul L
OK, if you fellows want to be picky, my heat riser valve was sticky yesterday. A little PB Blaster later.....
To Cold startup issue
