Well, I worked out a trade with a local chrome plater I know to get my bumpers redone. Trading the exterior chrome work for an old 5 hp boat motor I don't use anymore. All's right with the world so I proceed to pull off the bumpers and grills today.
At some point, one of the two previous owners decided to repaint the car. It turns out he LOST about half the bumper brackets, the center grill & it's mounting brackets, screwed up both L & R grilles. Cut one of the front bumper guards with a torch to remove a nut. Lost the outer bumper bracket extensions so he just bolted the front bumper DIRECTLY to the fiberglass - which is now screwed up. And stripped one of the bolt holes on the front bumper
FREAKING idiot! Not that I'm terribly surprised though. I should have known when the interior was redone with **** house carpet! Looks like I'll be paying a visit to the local specialty welder to get some stuff fixed. BTW are the front grills magnesium?
If anyone has a line on a center grill, shoot me a PM or email.
The front grillework [mesh] is pot-metal. If you apply too much heat to that stuff it just melts. It is nearly impossible to weld on it; only the most experienced [with pot-metal work] even attempt it. It is also very brittle...it won't bend, so if you put too much force into it the metal will just snap.
Interesting you say that. I have a '74 that had a broken bar in one of the grilles. I am not a weldor by trade, but have a TIG that I play with to fix up broken steel things. I switched it to the aluminum setting and had no trouble welding up the broken bar on the grille. Therefore the '74 grilles must be aluminum.
Mind you, the car in question has chrome bumpers, so is not a '74, and therefore the grilles might well be pot metal.
