'72 alarm switch removal???
Old Aug 16, 2010 | 02:12 PM
Sully1882's Avatar
Sully1882
Default '72 alarm switch removal???
OK, most everything else is removed from the car except this little key switch on the back of the car just above the CORVETTE lettering. I disconnected the wires and have the little backing plate off but it still won't budge. How does this thing come out?
thanks again,
Sully
Old Aug 16, 2010 | 02:50 PM
Gordonm's Avatar
Gordonm
If you have the backing plate off it should come out. Maybe it is stuck or painted in. With the "C" clip backing plate off that is what holds it in the switch should come out.
Old Aug 16, 2010 | 03:57 PM
oldsarge's Avatar
oldsarge
try to wiggle it out carefully, or cut paint with razor blade around the switch to help loosen it. That is if you are redoing your paint.
Old Aug 16, 2010 | 04:20 PM
Sully1882's Avatar
Sully1882
yep, this is what I was planning on doing was to razor around the edge and then tap it from behind. New paint is the reason for removal anyways! I will let you guys know how it goes.
thanks again,
Sully
Old Aug 19, 2010 | 10:50 AM
Sully1882's Avatar
Sully1882
traced the exterior with a razor blade then got a hand on the back and worked it loose. Came right on out...
thanks for the help guys!
Sully
To '72 alarm switch removal???
