383 Stroker In My 75
Old Aug 17, 2010 | 11:27 PM
tbschilz's Avatar
tbschilz
Default 383 Stroker In My 75
Just Put A 383 Stroker In My 75 With 4 Speed, Put A Holly 600 CFM On
With A Eldenbrock Manifold, Built With Stage 3 Cam, Took Some Work To Get Timed But Finaly Got It, Very Impressed With The Power, Got A 2.5 Dual Exhaust On, Hopfully The Drive Line Holds Up To The Torque,
Next I Need To Get A Hot Box For The HEI.
Old Aug 18, 2010 | 04:27 AM
Birdman's Avatar
Birdman
I'm thinking about putting a SB 427 in mine....do you think a Holly 600cfm Barry Grant Road Demon would be too small?
Old Aug 18, 2010 | 08:12 AM
L88Plus's Avatar
L88Plus
Yes, unless you don't want to rev over about 5 grand I've seen too many folks having trouble with anything by Barry Grant, a good 750DP should fit the bill perfectly.
Old Aug 18, 2010 | 10:06 AM
Dantana's Avatar
Dantana
I was thinking that 600 cfm is a little shyon the cfm's for a 383, especially with the 4 Speed... heck I've got a 670 on my ZZ4 and it's an automatic
Old Aug 18, 2010 | 11:07 AM
SteveG75's Avatar
SteveG75
Get in touch with Lars up in Lafayette. He will help you tune up a nice 750 for that 383.
Old Aug 18, 2010 | 11:52 AM
jordan89's Avatar
jordan89
He's a very knowledgeable guy and will get it running right with a bigger carb.
Old Aug 18, 2010 | 09:08 PM
glen242's Avatar
glen242
I am running a Lars built Q-Jet on my 383.
Q-Jet = 750 cfm minimum!
Old Aug 18, 2010 | 09:43 PM
Rollochrome's Avatar
Rollochrome
The 383 Stroker in my 79 came with a rebuilt 600 cfm Rochester.
Under hard acceleration, the carb would run itself out of gas and cause me to have start and stop acceleration.
I am in the process of replacing it with a Edelbrock 750 and a much improved fuel pump....along with two dozen other upgrades...
Fwiw.......
Stroker is a mad motor!!! Me likeee!!!
Old Aug 18, 2010 | 11:33 PM
snoopykissedlucy's Avatar
snoopykissedlucy
I'm putting in a 383 stroker in my 1981....quick question:
Are you using 1 5/8 or 1 3/4 inch primary headers?
I've got some Edelbrock RPM heads and they call for 1 3/4 headers but 1 5/8 headers are sooooo much cheaper.
Old Aug 20, 2010 | 12:22 AM
lars's Avatar
lars
Originally Posted by Rollochrome
The 383 Stroker in my 79 came with a rebuilt 600 cfm Rochester. Under hard acceleration, the carb would run itself out of gas and cause me to have start and stop acceleration.
There is no such thing as a 600 cfm Rochester Q-Jet. All Q-Jets, with a few 800 cfm exceptions, are 750 cfm.
If the carb was "running out of gas," you either have a fuel supply problem or a carb setup problem. There is no problem with the size of your 750 cfm Q-Jet. You would be better off fixing your fuel problems and carb tuning problems than switching to another carb of the same size and re-tuning it.
Lars
To 383 Stroker In My 75
