control arm bushing removal??
Old Aug 18, 2010 | 09:38 PM
mj9311's Avatar
mj9311
Default control arm bushing removal??
whats the easiest way to get them out??
Old Aug 18, 2010 | 10:01 PM
crf311's Avatar
crf311
drill out the rubber. I think I drilled about 50 in each bushing, the more he better. Then you can know out with a hammer or use a press. The centers will come out first. Then remove the shafts, support the a arm and know the outer part of the bushing. Hope this helps.
Old Aug 18, 2010 | 11:39 PM
mj9311's Avatar
mj9311
i can get the center out no problem but i cant get the outer shell out...
Old Aug 19, 2010 | 06:31 AM
Woodsters's Avatar
Woodsters
If you've removed all the rubber.... then...
Get a BIG chisel a BIG hammer and one glove. Glove on left hand (if you're right handed), chisel on metal sleeve. Strike the chisel with enough force to bend the sleeve inwards. A couple good blows and it will be bent enough to tap out. No picture of control arm, but the trailing arm is similar. Check out the photos on #9, #10 and #11, post #27.
http://forums.corvetteforum.com/c3-g...post1573241152
Good luck. David
Old Aug 19, 2010 | 07:37 AM
Indiancreek's Avatar
Indiancreek
That's a lot of hand work. I keep some bar stock in the shop to keep the arm from being damaged and soak overnight in blaster. Next day press them out. Now and the a little help with a hammer.
I charge $15 per bushing here. The press does most the work. If the arm isn't supported in the inside the arm can be distorted.
I'd ask them at your local automotive machine shop see what the cost may be. Might be worth it.
Old Aug 19, 2010 | 08:48 AM
damoroso's Avatar
damoroso
Easiest way is with a vise and an air chisel using a flat or hammer bit. It's actually easier with the rubber in, but can easily be done with it out. Short of that, hammer and chisel....
Old Aug 19, 2010 | 09:02 AM
crvtownr's Avatar
crvtownr
http://www.lbfun.com/warehouse/tech_...%20rebuild.pdf
Old Aug 19, 2010 | 09:14 AM
ZZ71S's Avatar
ZZ71S
I tried the hammer and chisel but mine where in there very good so I used a sal saw and cut a very small piece of the bushing shell out and bent it together to remove it.
I would only try this as a last resort it would be very easy to cut the A arm.
Old Aug 19, 2010 | 09:30 AM
thegazman's Avatar
thegazman
Default thegazman
The vibration of the air chisel seems to work well. When you install the new bushings put them in the freezer for a couple of hours. They shrink and slide into place easily. As they warm up they become tight.
Old Aug 19, 2010 | 09:46 AM
z10kl's Avatar
z10kl
sal saw = saws all
Old Aug 19, 2010 | 09:28 PM
mj9311's Avatar
mj9311
Originally Posted by z10kl
sal saw = saws all
i have a plasma cutter i think that might work if im careful
Old Aug 20, 2010 | 11:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Burn the old rubber away with a torch. Stinks, but works. A chisel will open the sleeve if it's sticky.
Old Aug 20, 2010 | 11:43 AM
mj9311's Avatar
mj9311
and how about pressing them back in??
Old Aug 20, 2010 | 01:47 PM
Easy Mike's Avatar
Easy Mike
Straightforward with a press.
Old Aug 20, 2010 | 01:56 PM
mj9311's Avatar
mj9311
i dont have a press
Old Aug 20, 2010 | 06:11 PM
Woodsters's Avatar
Woodsters
If you want to do the work, you need the tools. Buy a press and learn to use it. Harbor freight has a decent entry level model (go for a 20 ton unit) that you can pick up for around $175. Like "Indiancreek" said, get several pieces of bar stock, flat stock, etc to keep on hand to support your work when you are using the press.
Just for comparison... My local Pepboys charges $18 per bushing (for press-in). If this is your only project, pay someone. If not, buy the press and you'll have it for other projects.
Old Aug 21, 2010 | 01:29 AM
mj9311's Avatar
mj9311
so instead of buying one i just made one from some angel and channel i had lying around... its not pretty but it seems to be doing the trick so far
To control arm bushing removal??
