71 Coil Resister
Old Aug 21, 2010 | 10:50 PM
CraigH's Avatar
CraigH
Originally Posted by petes74ttop
Did I read that correctly? What kind of device do you want to install that only gets power with the key in START.
If that's what you need then you could take the power from the same "S" terminal on the solenoid.
Regards,
Pete.
Hi Pete
No I was after an ignition wire but not one that had a resister in it.
I have another thread around the CEC wiring that i had hoped would solve it but looks like i will just have to use the one I have run from the fuse box.
