74 big block drivetrain
Old Aug 20, 2010 | 04:24 PM
RiseAbove's Avatar
RiseAbove
Default 74 big block drivetrain
how much power can the stock auto trans and rear handle?
Old Aug 20, 2010 | 05:23 PM
hugie82's Avatar
hugie82
I ran a BB427 (400hp) in my 74 with the stock 350 power train but mine was a 4spd. with no problems. My Cutlass had a 455 with the th350 and it lived for a while. About 20,000 *** thrashed miles before the torque converter blew...
Old Aug 20, 2010 | 05:29 PM
RiseAbove's Avatar
RiseAbove
well its getting a 496 stroker with around 860 (flywheel) hp just seeing how long the 400 will hold up before it goes KABOOM
Old Aug 20, 2010 | 05:40 PM
68/70Vette's Avatar
68/70Vette
This question has been discussed before in previous threads.
My old brain remembers that with an automatic, street tires - no more than 10 inch treads for sure, you could go with 600 to 650hp. I think I can remember the 650 hp figure being quoted by Tom of Tom's Differential.
Remember that the L88's (67-69) had 550 hp, manual transmissions, and the rear ends- same as production cars differentials, BB u-joints, BB-half axles, etc would hold up under road races.
There's a lot of improvements in C3 rear end's that are now available. Since it's pretty expensive to blow up a rear end, it would be prudent to upgrade it with improvements today even if you're only planning on 500 hp. There are some relatively inexpensive (!) things that will upgrade the strength of you rear end. Van Steel is a forum sponsor that will know what to do. Also, Tom at Tom's Differential. Tom no longer rebuilds units, but only sell parts many of which are custom made by OEM manufacturers just for him. Tom is a good source of advice although be forewarned he likes to keep conversations short.
Old Aug 20, 2010 | 05:43 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
The rear will go before the TH-400. 860 HP? You'll need to upgrade everything in the drivetrain between the rear lugs and the harmonic balancer.
To 74 big block drivetrain
