Fuel Line problem, need pics and help!
Old Aug 21, 2010 | 11:16 AM
phclub's Avatar
phclub
New England Events Coordinator
Default Fuel Line problem, need pics and help!
Relpacing the steel line from pump to carb, the heater hose off the manifold is smack in the way of the line. Can you share pics and thoughts on how to configure the line around the hose/fitting?
1970 350, no air no power brake or steering
Old Aug 21, 2010 | 01:19 PM
rcread's Avatar
rcread
Mine goes under the hose, shown below. Your line might not be bent quite right.
Old Aug 21, 2010 | 01:28 PM
Duke94's Avatar
Duke94
Here's my 71'
Gary
Old Aug 21, 2010 | 02:04 PM
Alan 71's Avatar
Alan 71
Hi PHC,
Even on original cars the line is VERY close to the heater hose. I've seen reproduction lines that pass below the hose and also above it. Here's a picture of a repro line passing above the hose
I do believe though, that it passed below the hose at least some of the time in the 71 model year.
Regards,
Alan
l\
Old Aug 21, 2010 | 02:52 PM
phclub's Avatar
phclub
Thanks for the pics guys, that helped a lot. I an under the hose. I also called my brother in law, the engineer with just about evey tool imaginable. The tool he recommended was the tube bender, $5.95 at Pep Boys, many tries at bending and re-bending. Got the darn rubber line out, metal in, ran her tested for leaks, everything look A-ok. I think I will plan the hoses from frame to pump another day, Miller Time. Celebrate each success as it happens.
Old Aug 22, 2010 | 08:28 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I think that's one of the few places you want to keep the rubber line.
Old Aug 22, 2010 | 09:22 AM
phclub's Avatar
phclub
Yes, indeed, I have the new rubber lines inhand, just need another reason to have another succsess and Miller Time celebration. Cheers!
Old Aug 23, 2010 | 03:07 PM
phclub's Avatar
phclub
Originally Posted by Alan 71
Hi PHC,
Regards,
Alan
l\
Alan, a seperate question, on that very clear pic, where does the vacuum line at the top of the carb with white stripe go to?
Old Aug 25, 2010 | 06:05 PM
Alan 71's Avatar
Alan 71
Hi phc,
That white striped hose runs directly to the small port on the charcoal canister lid.
The canister has 2 large hoses, 1 from the gas tank and 1 from the pvc valve; and that 1 small hose.
Regards,
Alan
To Fuel Line problem, need pics and help!
