Headers for angle plug heads
Old Aug 22, 2010 | 05:49 PM
k_daddy's Avatar
k_daddy
6th Gear
Default Headers for angle plug heads
I've got a stock ZZ4 that is going in my '78 so I need something that will fit the angle plug heads. I want quality and was looking at getting some coated Hookers through Jet Hot. Unfortunately, the Comp headers won't fit angle plugs. Super Comps will, but they have 1 3/4" tubes as opposed to the Comps' 1 5/8". It seems like it might be overkill to be running 1 3/4" tubes for a fairly mild 350. Thoughts? Will this have negative impact on performance?
Old Aug 22, 2010 | 07:00 PM
TopGunn's Avatar
TopGunn
I had Flotech ceramic coated mheaders on my ZZ4 and had access to all the plugs, no problem. The coating seems to get a matt finish after a while.
Old Aug 22, 2010 | 10:47 PM
k_daddy's Avatar
k_daddy
6th Gear
How was the seal? What kind of gaskets did you use, and did you have any leak problems? Also, you replied in the past tense...how long did you run those headers?
Old Aug 22, 2010 | 11:18 PM
TopGunn's Avatar
TopGunn
The seal was perfect, no leaks. I replied in the past tense only because I changed the heads to Brodix IK-180's. I still run the headers on them without any leaks but getting to one plug is a bitch and one plug is real close to one of the tubes. With the angle plug heads no problem at all.
I used the gaskets that came with them. Put a coat of grease on them and tightened the bolts...........never a leak.
Old Aug 23, 2010 | 12:26 AM
k_daddy's Avatar
k_daddy
6th Gear
Thanks for the info! One last question: As far as the install goes, any clearance issues (i.e. starter) or modifications you had to do to get them bolted on to your original ZZ4 heads?
Old Aug 23, 2010 | 06:14 AM
TopGunn's Avatar
TopGunn
No installation issues at all. I still have the heatshield on the starter, no modifications anywhere, these bolted right up.
Check the flanges carefully before you put them on, there were a couple of places with some weld spatter on mine, I just carefully ground it off.
Old Aug 26, 2010 | 01:01 PM
tracdogg2's Avatar
tracdogg2
The summit racing brand headers are Flowtechs. Excellent fit with angle plug heads.
Mike
Old Aug 26, 2010 | 05:06 PM
FKING1's Avatar
FKING1
FYI, ZZ4 has D shaped exhaust ports not square.
Hedman makes Headers with D ports for the ZZ4.
Have them on my ZZ4. I thought the ZZ4 had straight plugs, at least seems that way in looking at mine.
Old Aug 26, 2010 | 08:13 PM
SteveG75's Avatar
SteveG75
ZZ4 heads have the L-98 angles. They are not the same as the old Chevrolet angled plug heads that Hooker is referring to. So, the Hookers may fit, especially with shorty plugs. Best thing to do is order them from a reputable dealer that will work with a return if they don't fit.
Old Aug 28, 2010 | 12:46 AM
k_daddy's Avatar
k_daddy
6th Gear
I decided to drop the cash for the Jet Hot coated Super Comps. I'll let you know how it all works out when they get here.
Old Aug 28, 2010 | 12:52 AM
crf311's Avatar
crf311
Dynomax headers worked fine with my ZZ4 heads
To Headers for angle plug heads
