Air pulley removal
Old Aug 26, 2010 | 12:02 PM
pippo350's Avatar
pippo350
Default Air pulley removal
Hi guys,
I'm just thinking to remove the air pulley I dont have AIR pump installed.In this way I will have more room for spreader bar and less weight in the engine.
Can I remove it and use the same bolts or I need some modification?
[IMG] Uploaded with ImageShack.us[/IMG]
Any advice are appreciated.
Giuseppe
Old Aug 26, 2010 | 01:22 PM
terry82's Avatar
terry82
are you wanting to change the water pump pully ?yes you can with out using differant bolts.
Old Aug 26, 2010 | 01:36 PM
pippo350's Avatar
pippo350
Yes !
Now I'm going to take off the first one on the right side beside the fun.
During the winter I want switch with a single groove water pump pulley.
I don't have the A/C in the car and I dont need 2 groove pulley.
I'm looking for a chrome/aluminum set.
Just a question,my water pump is short style or long style?
Thanks for the answer terry
Giuseppe
Old Aug 26, 2010 | 02:15 PM
snoopykissedlucy's Avatar
snoopykissedlucy
You have a short water pump. The way to tell is when the water pump almost touches the timing chain cover....thats a short water pump.
If you can stick your finger between the water pump and timing chain cover, then its a long water pump.
Visually, the square cap on top of the pump is located in the middle, that means its a short pump. A long water pump has the outlet at an angle.
Old Aug 26, 2010 | 02:25 PM
pippo350's Avatar
pippo350
Thank you !
I appreciate your help !
Old Aug 26, 2010 | 02:35 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Why not keep the double pulley and run a short belt from the crank to the water pump like early big blocks did?
Since there's no idler pulley you may need to remove the water pump pulley to get it on and off, tho.
Old Aug 26, 2010 | 02:56 PM
pippo350's Avatar
pippo350
And the alternator how it work?
I'm think at this set up:
water pump pulley w/1 groove and cranck pulley with 2 grooves,booth billet aluminum.
It's correct?
Old Aug 26, 2010 | 03:33 PM
KapsSA's Avatar
KapsSA
The alternator stays as is and the power steering stays as is.
The short belt would just fill the empty grooves, center on the crank, outermost on the water pump.
Just thought I'd save you buying new pulleys, didn't know you were going with the billet aluminum, tho.
Old Sep 2, 2010 | 01:03 PM
pippo350's Avatar
pippo350
The work are done !
Now start to cleaning the engine bay.
Now I'm tryng to figure how is the best pulleys combo.
Ineed the water pump pulley with single groove and the Crankshaft with 2 groove.
I need some spacer/adapter when I change the pulley?
Can someone can tell me the best combo to install?
I have read if I install an aluminum pulley kit you will have less drag on the engine and more HP on the wheel.This is real Advantage?
To Air pulley removal
