BB Engine Mount "V" Spacers
Old Aug 27, 2010 | 12:11 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Default BB Engine Mount "V" Spacers
On one of my 73's (w/ 454), I'm curious about the "V" shaped spacers between the engine mounts (motor mounts) and the block. Obviously, they were needed to raise the engine a bit (3/16"?).
What is the reason for elevating the engine? Driveshaft angle? Fan-to-shroud clearance? Exhaust clearance? Other?
I'm told only BB's with A/C had these spacers installed at the factory. Can you confirm?
Old Aug 27, 2010 | 12:42 PM
mudbone64's Avatar
mudbone64
From: I'd like to propose a toast... to internal combustion and wind in the face.
I don't know whether or not '72 big block a.c. cars were supposed to have them but I do know that mine does not and I don't have any drive shaft angle or fan to shroud clearance issues.
Old Aug 27, 2010 | 02:39 PM
73, Dark Blue 454
Mudbone,..does your 72 BB have factory air?
Old Aug 27, 2010 | 03:02 PM
Steve439's Avatar
Steve439
Noland's mid-year book says the shim was used in big block A/C cars to keep the carb float bowls level.
I'd assume it's the same for later years...
Old Aug 27, 2010 | 03:40 PM
73, Dark Blue 454
Hmmm,..
Old Aug 27, 2010 | 05:26 PM
68/70Vette's Avatar
68/70Vette
70 BB with air. It has the V shims.
Old Aug 27, 2010 | 08:50 PM
mudbone64's Avatar
mudbone64
Yes it is. I do know for a fact the engine had been out of the car at one point before I owned it. I'd say someone just forgot them and when I had the engine out I never thought to re-install them. However, like I said before I haven't noticed any adverse effects that can be attributed to the absence of the shims.
Last edited by mudbone64; Aug 27, 2010 at 10:13 PM. Reason: I can't write sentences.
Old Aug 27, 2010 | 09:28 PM
Neptune75's Avatar
Neptune75
A little of topic but when i put a big block in my 1975 i didn't use the spacers, i used hooker super comp headers and my headers where dimpled to clearance the steering box, when i installed the headers they hit the steering box. i talked to a corvette shop here in michigan he said (did you put the v spacers behind the motor mounts?) i said huh? i have since installed them with no clearance problems on the headers.
Old Aug 28, 2010 | 12:00 AM
Rebelrob's Avatar
Rebelrob
V spacers? Lets see a pic of these V spacers.
Is this the extra plate that is on the back connects to the back of the mount?
Old Aug 28, 2010 | 12:10 AM
73, Dark Blue 454
Here's a photo:
https://www.paragoncorvette.com/p-35...ine-mount.aspx
Old Aug 28, 2010 | 12:12 AM
73, Dark Blue 454
Why the heck would A/C on a BB necessitate the need for these spacers?
Old Aug 28, 2010 | 09:11 AM
DS68tripwr's Avatar
DS68tripwr
Dark Blue,
When I bought my 68 in 1998 the car had not seen the road for 20yrs. The drivetrain is origonal, 427 - 400 with 4 speed. It does not have air cond or power steering. When i pulled the engine the shims were in place and looked like they had been there since the car left St. Louis. The only reason for the spacers I can think of is to slightly elevate the engine. I have learned over the years that I have owned this particular car is sometimes the books are not always correct.
Old Aug 28, 2010 | 10:16 AM
BBCorv70's Avatar
BBCorv70
Don't know why A/C makes a difference but people are right, the shims appear under the C60 option (A/C) when a big block is installed.
Option C60, page C2, 1970 AIM.
To BB Engine Mount "V" Spacers
