oil pan gasket
Old Aug 28, 2010 | 07:57 AM
whiteflame's Avatar
whiteflame
Default oil pan gasket
Do i need to lift the engine or take anything loose to change the oil pan gasket on a 1974 corvette 350 automatic ? Thnx Dave
Old Aug 28, 2010 | 08:40 AM
JimT's Avatar
JimT
On my '72, 350cu Vette, I drop one side of the steering linkage - passenger side. No other alterations need to be done. The pan will drop in the rear then slide rearward for removal. I use the blue felpro one piece gasket.
Old Aug 28, 2010 | 09:52 AM
7T1vette's Avatar
7T1vette
Remove the two [frame] mounting bolts on the idler arm, then just let the steering links drop away from the pan. Easy removal after that.
Old Aug 28, 2010 | 10:15 AM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
+1 for the felpro one piece.
Old Aug 28, 2010 | 12:21 PM
whiteflame's Avatar
whiteflame
Hey , thnx for the help fellas, Dave
Old Aug 28, 2010 | 12:32 PM
jordan89's Avatar
jordan89
To oil pan gasket
