C3 corvette brakes
Old Aug 27, 2010 | 08:22 PM
Brandon50394's Avatar
Brandon50394
Default C3 corvette brakes
My brake petal goes to the floor when I brake when I got the car and I was bleeding the brakes I discovered that the two bleeders on the left rear of the car are snapped off is it probaly just air in the lines
Old Aug 27, 2010 | 09:45 PM
Timsride's Avatar
Timsride
I would lift each wheel off the ground and have someone press the brakes and see if brake holds wheel stationary. You may find the left rear wont work at all. Usually when a bleeder brakes off You cant seal it. There may be more problems with that caliper but hopefully not.
Old Aug 27, 2010 | 11:46 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
What is your question?
To C3 corvette brakes
