2 problems...
Old Aug 29, 2010 | 08:26 AM
KevinK's Avatar
KevinK
Default 2 problems...
...possibly related. Problem one is, under hard acceleration, it backfires when shifting up to the next gear, the moment I push the cluth pedal in. Seems to only do it at higher rpms.
So...I thought maybe my firing order might have gotten crossed somewhere when I changed the sparks plugs, so I popped the hood and chased wires, but they are in the correct firing order. HOWEVER, with the engine running, I was poking around, and saw that the spark plug for cylender 6 was arching. A tiny spark was hitting the header tube, and it was coming right from the boot! So I checked the others, specially the ones that sit closer to the header tubes, but no arching. Furthermore, 6 was arching to a rythm...no arching for a few secs, then 6-7 consecutive archs, then no archs, etc etc.
The wires are MSD street fire wires. The boots for 3,4,5, & 6 sit very close to the block hugger headers. Even if stock, though, they would sit just as close to the old rams horns. Plus, 3,4 and 5 seem to have no issue with this. Are these two issues related, and what can I do to fix them?
Old Aug 29, 2010 | 09:03 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Bad wires. Usually when a wire starts arcing it creates a path of carbon that is difficult to repair. If a little bit of dielectric grease around the inside edge of the boot does not fix it then the wires and possibly the plugs need to be replaced. That could cause the backfire issue, but so could a lean fuel mix. Check for vacuum leaks, too. Hoses and the carb base gasket are good places to look. High mileage or abused engines create new sources of problems, but start simple.
Old Aug 29, 2010 | 04:31 PM
KevinK's Avatar
KevinK
Hit the spark plug with some dielectric grease, fired it up, and it still arks. Pretty angry, as I just bought and installed these MSD wires 4 days ago.
Old Aug 29, 2010 | 06:43 PM
CaseyJones's Avatar
CaseyJones
Are they arcing from the base of the boot where the wire goes in or the open end around the plug? Arcing at the base means you take them back. Arcing around the plug end means the plug may have enough dirt\grease\whatever that the current has a path out to the header tube.
Old Aug 29, 2010 | 07:29 PM
KevinK's Avatar
KevinK
They are arcing about halfway between the open end where the plug goes in and the 90 degree angle in the boot.
Old Aug 29, 2010 | 07:49 PM
CaseyJones's Avatar
CaseyJones
Bad wires for sure. Take them back and try again.
Old Aug 29, 2010 | 07:54 PM
KevinK's Avatar
KevinK
I gotta ship em', I got them from summit.
Old Aug 29, 2010 | 08:35 PM
Tim81's Avatar
Tim81
Have you try changing that spark plug on the arcing wire? Could be a crack in the plug insulator. Sometimes even new plugs are cracked.
Old Aug 30, 2010 | 12:17 AM
Project80's Avatar
Project80
It could be the plug as Tim81 stated. First, do you still have the old wires? Try putting the old one back on to see if it's the new wire.
Old Aug 31, 2010 | 03:34 AM
73StreetRace's Avatar
73StreetRace
Maybe your spark plug boots are too close from the headers so they burn quickly.
You could try shorty spark plugs like the ones ACCEL make. It would give extra clearance ( about 7 or 8 mm more ) and could save the life of your new wire set.
Arcing would also be reduced to a minimum with the extra distance to cross..
Old Aug 31, 2010 | 09:42 PM
KevinK's Avatar
KevinK
Replaced the spark plug, and no arcing. Gonna keep an eye on it...if it starts up again, I'l try those shorty pugs as suggested. Thanks, guys!
Still backfires, though...
Old Sep 1, 2010 | 12:56 PM
firstvett69's Avatar
firstvett69
Default Arcing wires ? backfire
If you find out that it is not the wires or plugs, here is a thought are you running the original smog pump ? if so rev the engine up and let off does the car steal backfire or at cruse and back off gas does it backfire, if so decel valve on the smog pump is bad and or the vacuum line from the decel valve is hooked up to the wrong vacuum source. 2 cents, I use to have many customers come in with this problem after someone worked on there cars, its a very easy mistake to make not putting the vacuum hoses back in the proper places. But this will also cause backfiring and usually it is big time.This may also help others that have backfiring issues and its not the usual carb, wires, timing, ex-ct. firstvett69.
Old Sep 1, 2010 | 07:44 PM
KevinK's Avatar
KevinK
So now it's arcing again, new spark plug, different wire....
Old Sep 2, 2010 | 02:51 AM
73StreetRace
IMHO, I think new spark plug boots AND shorty plugs is the way to go.
As long as it's still arcing, you won't solve your backfires issue.
You probably have some cylinders that sometimes misfires.
I'm using ACCEL 0576S ( S= Shorty ), but I'm not sure that your engine needs the same heat range, so first check equivalence with the ones you have...
Old Sep 2, 2010 | 12:04 PM
pauldana's Avatar
pauldana
Do you have headers? are thy ceramic coated if you do? I was burning MSD wire boot after boot after boot because of the heat, and that I would get arcing...changed to shorty plugs and ceramic headers... problem went away...
Old Sep 2, 2010 | 12:16 PM
73StreetRace
Even if ceramic headers upgrade isn't really what I would call a cheap fix...
Old Sep 2, 2010 | 01:02 PM
pauldana's Avatar
pauldana
well... maybe not, but I tried EVERYTHING... booties, different wires, different plugs, and spent I think more money trying different stuff than the new ceramic headers cost me.... also, I sold the old headers on ebay and got ~85% of my money back!!!
sometimes the Cheep way turns into the long and expensive way...
good luck... p:-)
Old Sep 2, 2010 | 03:51 PM
KevinK's Avatar
KevinK
They are shorty headers, but they are not ceramic. Before going that rout, I'll just get header wrap for them. It's just odd that this is only happening on the number 6 cylinder, and no others, seeing as number 5 on the other side is exactly the same.
Thanks for the input, guys.
To 2 problems...
