I changed out a caliper a month ago along with a lot of the lines in the wheel well area on my 69.
I used the Motive power bleeder and it worked great.
But it seems like every time I get in my car the brake pressure is different. Sometimes it's almost nonexistent(dangerous) while other times it is perfectly fine.
I don't know if i need to bleed the system some more due to maybe an air bubble in it or if something else is causing this....
Yeah I think I'll bleed the system tomorrow after work and see if it helps any.
It's just not very safe driving with minimal brake some of the time, I can get by but it just takes that one quick stop scenario and I'd be boned.
I hope bleeding does help but inconsistency in my experience has been the master cylinder.
Try sitting with the engine running and putting your foot on the brake like your stopped at a light and hold pressure, now lighten the pressure on the pedal slightly, then push down a little more, lighten , push , lighten ,push. If you can sneak the pedal to the floor the master is bad.
I don't want to admit it but I'm pretty sure I ran the master cylinder dry in one cell when i was changing out some of the lines. I know everyone has to bench bleed if that happens but when i got everything to bleed at the calipers i figured i was okay.
Is that the case? Could there still be air in the master even if I can get fluids at the calipers?
And what on a master cylinder usually goes bad?
Air can easily get stuck in the master cylinder , especially the rear cell , look for a little bubble in the hole in the bottom of the cell.
What I usually find that goes bad is the seals inside, no outside leak,the seals allow fluid to slip past them. (If you push really hard the seals hold but when you push easy the piston and seals just slip through the fluid.)
Until I went Hydro Boost on my '72 with vacuum booster, and the same thing on a motor home not long ago.....the pedal feel was all over the joint, vette had been HB for some 6? years now, and solid/consistent but until then I always had that bad feeling, and soft pedal....
in both cases, my swap to HB was done on a A-B basis, meaning I did not disturb the master cylinder/lines......been proven twice now...
on two greatly different vehicles...
You just needed a good mechanic to straighten out your factory setup.
Try tapping the bottom of the MC with a screw driver, or a wrench, and see if any bubbles come up. If so, you need to rebleed the MC, then rebleed the brakes.
There are 2 types of C3 brake people, those who have Hydro Boost, and those who have never tried Hydro Boost
$300, a little time ..... and an amazing upgrade!!
I had my brother drive my Vette with HB, and he is now converting his old Monte Carlo over to HB. Another convert sold!!
He says the only thing even close to it are the electro-mechanical brakes on the Mercedes cars, which he works on daily (mechanic) for electro-mechanical problems.
