wiring c3
Old Aug 30, 2010 | 12:39 PM
vett 68's Avatar
vett 68
Default wiring c3
can anyone tell me how hard it is to put in dash wiring harness, and engine compartment, is there any short cuts, any help will be thankfull, were is the best place to buy the wiring thank you pete
Old Aug 30, 2010 | 12:43 PM
Dantana's Avatar
Dantana
not that hard if you have all the stock components. Mine was full of aftermarket parts so a stock harness would only help with a percetage of what i would need to wire up.
It's a tedious job, unless you really love wires
Old Aug 30, 2010 | 01:52 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
LectricLimited or the vendors on the forum who sell LL. The assembly instruction manual (AIM) will be helpful before and during the project.
Old Aug 30, 2010 | 05:41 PM
KevinK's Avatar
KevinK
I'm looking at doing this next year. How much needs to be taken off to do this? I'm wanting to replace ALL wires, not just dash. Do the brake lights require body off?
Thanks in advance!
Old Aug 30, 2010 | 05:49 PM
vett 68's Avatar
vett 68
thanks for the help i've got to many grimlins in my wiring and mine in stock never been touched thanks peter
Old Aug 30, 2010 | 06:43 PM
Alan 71's Avatar
Alan 71
Hi Kevin,
No the body doesn't need to be off to change any of the electrical harnesses.
Regards,
Alan
Old Aug 30, 2010 | 07:55 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I did replaced both the engine and dash harnesses, with the engine out and all the interior parts removed, it was a very easy job. I imagine you can replace the engine harness fairly easy with the engine still in the car, but I can't see how you can do it with dash parts installed.
To wiring c3
