BB Water pump
Old Sep 2, 2010 | 09:20 AM
Black76's Avatar
Black76
Default BB Water pump
Im replacing the water pump on my big block but i see there is a short or long pump for them how do i tell which one i have.
Old Sep 2, 2010 | 09:36 AM
noonie's Avatar
noonie
Corvettes BB all take a pump that is 5.750" from clutch mount face to block mount face. (short)
Old Sep 2, 2010 | 09:42 AM
Black76's Avatar
Black76
but this BB didnt come from a corvette i belive it was out of a truck does that make a difference
Old Sep 2, 2010 | 11:07 AM
bashcraft's Avatar
bashcraft
If it's now in your corvette, it has a short pump on it.
Old Sep 2, 2010 | 11:48 AM
snoopykissedlucy's Avatar
snoopykissedlucy
If you can fit any finger between the water pump and timing chain cover, then you have a long water pump. The short water pump (big and small blocks) almost touch the timing chain cover.
I say this because I've seen long water pumps on small and big block Vettes.
Old Sep 2, 2010 | 08:01 PM
bigvette1's Avatar
bigvette1
Also, keep in mind that the shaft on the pump is 3/4" vs 5/8". Check the pump if you replace.
Old Sep 2, 2010 | 09:22 PM
noonie's Avatar
noonie
The 70 and older are 5/8" shaft.
To BB Water pump
