How do you clean a 1976 corvette engine? HELP
Old Sep 2, 2010 | 11:40 PM
flyfisher38's Avatar
flyfisher38
Default How do you clean a 1976 corvette engine? HELP
Do you just spray on degreaser or do you steam clean it? What do you have to remove from the engine when doing both or is it different for each?
Old Sep 3, 2010 | 12:47 AM
snoopykissedlucy's Avatar
snoopykissedlucy
Steam cleaning just makes a big mess. Stick to doing the cleaning with the engine in the car first. I use Formula 409 to cut the big grease.
Old Sep 3, 2010 | 12:52 PM
Rikoshay's Avatar
Rikoshay
When I got my car the front balancer had slipped and had been riding against the timing cover for quite a while and created a hole. The whole engine bay and most of the underside of the car was covered in grime (maybe that's why there's no rust).
I used Simple Green and a small dish washing brush on most of it. Oven cleaner from the Dollar store works well too, just be careful where you spray it. A few months ago I tried the "Purple Power" spray from AutoZone and it works a little better than the Simple Green.
Old Sep 3, 2010 | 02:26 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Cover the carb and the distributor and power wash it with water then blow off the water with a hand blower, I'm doing it for years now with very good results, never used any detergents.
To How do you clean a 1976 corvette engine? HELP
