Urethane bushing question
Old Mar 29, 2002 | 07:07 AM
Larry B.'s Avatar
Larry B.
Default Urethane bushing question
My 69 has urethane control arm bushings. The bolts seem to get loose over time because they can't lock onto the center piece like OEM bushings. I had another corvette that had urethane bushings and it had the same problem. I had to check them often and they always were a little loose. I even tried "680" loctite. So if any of you guys have urethane bushing be sure to check them from time to time. Any Ideas how to prevent this ? :cry
Old Mar 29, 2002 | 07:47 AM
Jvette73's Avatar
Jvette73
Default Re: Urethane bushing question (silvervetteman)
I too have the same problem with my controll arm bushing bolts comming loose. I have made it a regular stop on my frequent check list. Every time I check the fluids, I also check the controll arm bolts. It would be nice to find a permanent fix.
Old Mar 29, 2002 | 11:16 PM
Koz
Guest
Posts: n/a
Is this the same problem with urethane rear spring outer cushions too or just control arm bushings?
Old Mar 30, 2002 | 06:07 AM
Larry B.'s Avatar
Larry B.
Default Re: Urethane bushing question (Koz)
No... the only bolts that loosen are the four on the front control arms, because they rotate. :cool:
Old Mar 30, 2002 | 09:54 PM
Racer16k's Avatar
Racer16k
I have one that works it's way out after a while. Don't they make bolts with a nylon insert. I'm just glad it's not one of the bolts buried by the fan shroud!
Old Mar 31, 2002 | 07:34 AM
Jvette73's Avatar
Jvette73
Default Re: Urethane bushing question (Racer16k)
The first time mine loosened up the bolt actually fell all the way out. Then the bushing itself fell out also. I could tell the car was handling funny. When I got home I found the bushing in the driveway. I sure got lucky that it fell out there. I slid it back in with a new bolt and washer. Since then they have come loose one more time. Im always checkin em now.
Old Mar 31, 2002 | 07:43 AM
mrvette's Avatar
mrvette
I have had a Vette Brakes poly adjustable strut rod set under my car for allmost 6 years now, and it's been fine...I suspect the stock type rods probably are elongated in the loop ends, found that once on another car, thin metal, small diameter compared to the VB strut rods....
I just a month ago had to replace my VB rod bushings, finally just worn out...
GENE
Old Mar 31, 2002 | 07:56 AM
Larry B.'s Avatar
Larry B.
Default Re: Urethane bushing question (mrvette)
Thanks for the replies... I guess I'll just check the control arm bolts from time to time. :chevy
[Modified by silvervetteman, 6:02 AM 3/31/2002]
Old Mar 31, 2002 | 08:01 AM
Jvette73's Avatar
Jvette73
Mrvette, the problem we expierence is with the front lower controll arm bushings. Ive never had a problem with the strut rods in the rear.
Old Mar 31, 2002 | 08:05 AM
Larry B.'s Avatar
Larry B.
Default Re: Urethane bushing question (Jvette73)
My upper's were very loose. One bolt was almost out. I heard the washer rattling but couldn't find the rattle for a while.
Old Mar 31, 2002 | 08:10 AM
Jvette73's Avatar
Jvette73
Hmmm..its only been the lowers giving me trouble. Although now that im on the case, its not much trouble to periodocally check em.
Old Mar 31, 2002 | 08:12 AM
mrvette's Avatar
mrvette
OH for christsakes, too early in the morning, not enough coffee....too much boating yesterday, wife got sick on open ocean, up most of the nite...oh well...
at any rate, I have upper and lower controll arm poly bushings for 6 years now also. and never had a bolt loosen up, never...all I did was tighten down with an air hammer...
GENE
Old Mar 31, 2002 | 08:28 AM
Jvette73's Avatar
Jvette73
Mrvette, :lol: :lol: :lol: Hope the wife feels better. Hey man, if you stay up long enough you might be able to catch a buzz from sleep deprivation :cheers:
To Urethane bushing question
