(1968) Which 327 do I have ...327 w/300hp or 350hp?
Old 09-05-2010, 08:59 AM
capth4u
capth4u's Avatar
Default (1968) Which 327 do I have ...327 w/300hp or 350hp?
Hello, how can I tell which 327 I have on my 1968 ... the 327 w/300hp or 350hp? Is there something on the car that shows me? I have changed the intake manifold and carb. Any info you need to know please ask Thank you
Old 09-05-2010, 09:32 AM
Simmo
Simmo's Avatar
Pretty sure the 350 HP will have a higher redline on the tach, but I dont have numbers.
Old 09-05-2010, 09:50 AM
Paul L
Paul L's Avatar
What is the engine code?
Old 09-05-2010, 10:02 AM
Ironcross
Ironcross's Avatar
I normally associate a cast iron intake and painted valve covers instead of aluminum as the lower HP hydraulic engine or the base engine......also if the tach is not a 6500 red line it will not normally be a solid lifter high HP engine......But people change dress-up items available for performance motors to base engines and then intentionally confuse observers as to what engine is in the Vette......however the tach is almost 'never changed and is a good clue.....
Old 09-05-2010, 10:17 AM
Mike Ward
Mike Ward's Avatar
Didn't you say in another post that your engine is not original?
Old 09-05-2010, 10:26 AM
BBCorv70
BBCorv70's Avatar
Is the code still present on the block, in front of the right head?
Old 09-05-2010, 10:50 AM
Budman68
Budman68's Avatar
Cruise-In VII Veteran
St. Jude Donor '07
The easiest is the valve covers. 300hp painted, 350hp flash chrome, if original to the car.
BTW - I'll give you some cash for the carb that came off the motor. Email me pics to buddysingletary@gmail.com
Old 09-05-2010, 11:54 AM
carriljc
carriljc's Avatar
Default If your tranny tag is still there it might give you a hint...
If I remember right there is a little metal tag on the tranny. Take a look if your engine stamp is not visible.
Old 09-05-2010, 12:28 PM
Solid LT1
Solid LT1's Avatar
Tach RPM of redline is easiest way to tell 300HP=5500 redline 350HP=6000 redline.
Old 09-05-2010, 02:09 PM
shmoky
shmoky's Avatar
The suffix code will be HT if it is the 350HP.
shmoky
Old 09-05-2010, 03:04 PM
Birdman
Birdman's Avatar
Interesting...were these valve covers flash chromed, hence why they look crappy now?
Of course...anyone can swap covers...and I don't really remember what my redline was. I want to say 6000 but I'm probably just being optimistic.
Old 09-05-2010, 03:21 PM
Mike Ward
Mike Ward's Avatar
Those are C2 valve covers, not C3. As previously posted, you've got a mix and match set up that to me is just not right.
Old 09-05-2010, 03:47 PM
Paul L
Paul L's Avatar
shmoky
Yes, but he has not replied.
Old 09-05-2010, 04:50 PM
Budman68
Budman68's Avatar
St. Jude Donor '07
I had those c2 covers on my 68 chevy pickup. Everyone always asked if I have a corvette motor in my truck. lol
Old 09-05-2010, 04:52 PM
Budman68
Budman68's Avatar
St. Jude Donor '07
68 350hp covers
Old 09-05-2010, 06:00 PM
capth4u
capth4u's Avatar
Hello, the tach starts yellow at 5000 then orange at 5500 and redline at 7000... does that help? I have to check the numbers to make sure its the original engine .. I know the intake manifold was not original. Thanks for the information everyone
Old 09-05-2010, 06:02 PM
capth4u
capth4u's Avatar
shmoky
What is the suffix code?
To (1968) Which 327 do I have ...327 w/300hp or 350hp?
Old 09-05-2010, 06:40 PM
Budman68
Budman68's Avatar
St. Jude Donor '07
Front passenger side of the engine. There will be two sets of numbers. One the last digits of the vin and the other a suffix code. #'s and Letters. The vin will tell you if it is original.
Old 09-05-2010, 11:34 PM
Birdman
Birdman's Avatar
I had my dad check the tach..
"Yellow at 5800 red at 6000"
But I guess it doesn't matter since it wasn't an original motor! :S
Old 09-06-2010, 10:39 AM
Budman68
Budman68's Avatar
St. Jude Donor '07
Just clone it like I did. I found a date specific block and installed it. The front pad was erased during milling. If I ever wanted to have it judged, I could stamp it to complete the restoration or take deduct.
Quick Reply: (1968) Which 327 do I have ...327 w/300hp or 350hp?
