Power steering issue.
Old Sep 6, 2010 | 11:08 AM
thnk2mch's Avatar
thnk2mch
Default Power steering issue.
Due to the power steering control valve leaking fluid big time, I replaced the power steering control valve, and "while I was at it" I replaced the power steering cylinder and all four hoses.
I adjusted/balanced the valve per instructions.(with the cylinder still not yet connected at the frame, back and forth until balanced).
Everything seems great with the car in the air. When I drive it, it is as if I do not have power steering at all.
I have cycled the steering wheel left to right, while in the air to bleed dozens of times - no difference.
I drove the car thirty miles or so - no difference.
Prior to the new parts, the steering worked fine, just bled all over my garage floor.
Any ideas?
UPDATE 5-14-11: SEE BELOW
Old Sep 6, 2010 | 11:46 AM
SteveG75's Avatar
SteveG75
I had the same problem with a new PS control valve. Tried two different units with no power steering. Rebuilt my old one instead and had no more issues.
Old Sep 7, 2010 | 06:39 AM
thnk2mch's Avatar
thnk2mch
ttt
Old Sep 7, 2010 | 08:47 AM
303 Stingray's Avatar
303 Stingray
I went through a problem like this -- There are so many threads on this, you can search for mine. I bought all new parts then started--worked in air but not on the ground. to save money I rebuilt all the new parts one at a time, when that did not work, I then started replacing the new parts one at a time with other new parts (I had already sent the cores in). I found out I had purchased a bad cylinder, even after rebuild it did not work. I basically ended up buying 2 sets of everything. Who would think a cylinder could be bad? It worked in the air. After you have done all the line checking, bleeding and adjusting, If you still have the old parts just troubleshoot with them one at a time to narrow the problem. Good Luck.
Old Sep 7, 2010 | 09:42 AM
RAGTOP75's Avatar
RAGTOP75
LET ME TELL YOU ABOUT THIS!! I started replacing power steering control valaves 2 years ago, going thru the set-up just like you all did. I bought mine thru Auto Zone and ATZCO in Arizona is the re-builder for the units that Auto Zone buys from. I followed all the instructions to the letter about greasing them.....guess what, if you pump too much grease in them you blow out the gasket between the valve body and the hydraulic side which will cause them to leak. I went thru 7 different pscv units before I finally gave up on the Auto Zone (ATZCO) and bought a new aftermarket unit from "Corvette Sport" in Sheboygan Falls, Wisconsin, they sell CARDONE pscv and has better instructions with them. After research I found that CARDONE is one of the most respected suppliers of aftermarket parts...along with "LONESTAR". I will be buying all of my parts from CORVETTE SPORT from now on. They shipped me my part before I could ship them the core, they are GREAT TO DEAL WITH. Good Luck.
Old Sep 7, 2010 | 01:37 PM
7T1vette's Avatar
7T1vette
If your present power steering system is working but leaking, why would you spend big buck$ on buying rebuilt equipment [that may NOT work] when you can rebuild your own (functional) control valve for pocket change and have it up and running in a day???
Buy a $25 rebuild kit for the control valve, get your hands dirty...heck, they already are--you took it off the car...take it apart, clean it, put in new seals, paint it and reinstall. Why take the chance on vendor-rebuilt junk when you already have a 'serviceable' part?
Old Sep 7, 2010 | 01:59 PM
thnk2mch's Avatar
thnk2mch
Thanks for all the responses...
Bought a new one, not rebuilt. I saw the rebuild kits, but I did not want to "guess" that what I would get in the kit would take care of my issues, and risk having to take it back out and buy new anyways. I am no expert. My thought was if I was going to spend a day on it, I would go new and not have to worry about it.
Old Sep 7, 2010 | 07:07 PM
ED79's Avatar
ED79
Same thing for me, except from my previous owner's rebuild system, it was stiff when I bought it, so I just bought a new Lonestar (since it was leaking) and it's still stiff not sure what to do either, but I understand your situation and hope we can figure it out because it should be easier than it is. Ed
Old May 14, 2011 | 09:58 AM
thnk2mch's Avatar
thnk2mch
Update:
After many different attempts at resolving my power steering issues, like removing the new hoses and checking for blockage and reinstalling, having the power steering control valve I purchase exchanged for another one and reinstalling, and swapping back to my previous cylinder all with no difference, I replaced the power steering pump and
Power steering works great.
Go figure...
Old May 14, 2011 | 07:56 PM
Rmodeler's Avatar
Rmodeler
Same thing for me. First replaced control valve(new),power steering cylinder, 2nd hoses, pump(reblt)-all from Eklers. No difference. How difficult is it to check the pressure from the pump? I'm beginning to think the trouble is in the steering box.
Old May 14, 2011 | 08:09 PM
jb78L-82's Avatar
jb78L-82
I must say that I am sold on rebuilding the power steering components myself since I definitely do not trust any rebuilt components. just went through this with the PS pump. Decided to rebuild it myself with a $20 kit and it works perfectly and it is the original one with my 78 L-82 4Speed with 65,000 miles on it. It was relatively easy!!
Old May 14, 2011 | 10:41 PM
RU7376vettes's Avatar
RU7376vettes
Check some of the older Power Steering threads. Jim Shea has written about this as well as others. If you didn't bleed the system properly when you started it back up you may have gotten the pressure relief valve spool in the pump jammed. You might be lucky enough to get it loose with a magnet or you may have to pull the pump to get it loose. Then before you start it up make certain you turn the wheel lock to lock several times to 'bleed' the system before you actually start it up. If you didn't properly bleed the system when you reassembled all the new components, there is a very good chance you jammed the valve spool. If it is jammed it will drive like there is no power steering.
Unk
To Power steering issue.
